Door Closer for big & heavy front door
26 May 2007
Bristol
Hello All,
The front door to our Vic Terrace house is massive & heavy. The bldg is broken up into 5 flats and we live in the GFF next to the door. Most of the people who live here are considerate, but some aren't. :( There's now two nurses in the basement flat who are really suffering as they work unsociable hours in A&E. We've put up polite notices, etc., but it doesn't help with the clueless. Our family owns the building and we've decided to put in a decent door closer. Other houses on the terrace have them, but they don't seem to do a very good job, so I thought I'd ask here.
I don't actually know how heavy our door is so as to know what to be looking for. I've put a large collage pic on the page below with dimensions included. If anyone can tell the weight that would be a help. Any suggestions for a door closer would be magnificent!
Edit: I think the door is pine.
:) Lew
http://www.laurenwb.pwp.blueyonder.co.uk/FrontDoorCloser.htm
depends how much you want to spend,do you want it to be strong enough to pull the door shut or rely on its speed to do the job?
if money isnt an issue then www.lcnclosers.com do the best closers and most decent locksmiths/architectural ironmongers can get them for you.
ideally any closer you choose needs latching/closing and backcheck adjustment and at least a size 5 going off those measurements
£30 will get you a rubbish closer that will not do the job at all,£80-£90+ will get you something that will have the ability to shut the door quietly and last for years
briton (www.briton.co.uk) also do a decent range although i dont rate them personally
