Hi
I've recently carried out a repair on a Baxi HE133Plus boiler(combi) which involved a drain down. I followed the instructions to open all vents etc for drain down but I am not sure at what level of opening the Automatic Air Vent should be at? The boiler filled ok with no problems and I have good pressure although it fluctuates from time to time even with a radiator bleed (no air at all present in the rads)
The boiler has been working fine since the repair (over a month ago now) but I have been wondering about the air vent. The vent iteselt has a small plastic cap on it. Should this be screwed tighly closed or loose? If I loosen it, a small drip appears from the valve but then stops.
Can anyon advise please?
Anth
Anth
