Hi All,
I'm hoping someone has seen this problem before...
I've a new Vaillant ecoTEC installed a couple of months ago. All seems to be working well, but recently I turned up the temp from 54C to 62C and I cant remember if it was that night or the night after that I saw the water all over the floor.
This is the 2nd time this has happened. First time I had fed a little water into the system as i thought there was a pressure drop according to the indicator on the boiler (I had a slow leaking rad at the time - now fixed!)
There's no loss of pressure according to the boiler indicator even after the water has leaked out.
Toying with the theory that this could be a result of condensate but it is a lot of water...
Any advice greatly appreciated.
With thanks,
banman
With thanks,
banman
