DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Draft under the upstairs floor boards
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Author Message
jonnybegood
from United Kingdom
PostPosted: Mon Nov 19, 2007 9:46 pm Reply with quote
I have recently purchased a 1960s semi and was changing the downstairs light fittings when I felt a draft coming through the ceiling, connected the light fitting and thought no more of it.
No the colder weather is settling in I have found that in the airing cupboard upstairs that has no carpets fitted just floorboards there is a draft coming up through the boards.
Any ideas where the draft is likely to be coming from?
Its usually not an issue but as I say now the weather is colder when upstairs you can feel the cold through the carpet, I was thinking its coming from the cavity where there are possibly electrical cable or waste water pipes been drilled through between the ground and first floor.
Don't really want to be ripping carpets and floorboards to find its a waste of time.
One other place I have considered is the kitchen area where we have halogen downlights, the kitchen area is cold as its part of the flat roof extension and we often get draft coming through the downlights on the flat roof and into the kitchen, just thought that maybe this draft is then being sucked up through the kitchen downlights on the original kitchen side and into the house.
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 50 times
PostPosted: Mon Nov 19, 2007 9:52 pm Reply with quote
its a sign of good ventilation. This is normal and a good sign as it stops condensation etc from roting your boards. To stop the draft blowing through the board gaps you need to over board the floorboards with plywood.
Back to top
 Alert Moderators
jonnybegood
from United Kingdom
PostPosted: Mon Nov 19, 2007 10:12 pm Reply with quote
Thanks Matt.
So its a case of leave well alone then, was thinking of fitting new carpets with some good quality underlay.
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 50 times
PostPosted: Mon Nov 19, 2007 10:36 pm Reply with quote
ye you can do this but you will find that you will get black lines where the underlay joins ( the dust getting pulled through ) You can get around this by taping the joins , but then the dust will move to where the underlay is cut into the gripper! to get around this you need to put paper felt down or 'plywood' ! But then you will get dust mark around the edge of the room ! To stop this you need to seal the bottom of the skirting board to the sub floor!
Back to top
 Alert Moderators
jonnybegood
from United Kingdom
PostPosted: Mon Nov 19, 2007 11:32 pm Reply with quote
Matt out of curiosity where is this draft likely to be coming from? My parents home same year built, cavity walled etc has exposed floorboards in 2 of the bedrooms up stairs and no draft.
At the moment exposing and sanding my boards is not an option due to the amount of draft it would create in the room.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1511 times
PostPosted: Mon Nov 19, 2007 11:35 pm Reply with quote
as it's not a ground floor, there shouldn't be a damp prob.
if it was mine I would be stuffing loft insulation around the perimeter of the room by taking up the edge floorboards. It will avoid black staining too.
draught is probaby getting in where joists are loose in the inner leaf
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
thumping great draft between skirting and laminate floor 4 160 Mon Dec 30, 2013 12:34 pm
Draft under floor 3 220 Fri Nov 05, 2010 4:03 pm
Please help with a draft problem. It's driving me crazy 13 2300 Fri Feb 13, 2009 7:45 pm
simple draft question 4 620 Tue Mar 11, 2008 8:20 pm
Gap betw skirting boards/floor of upstairs bedroom 5 300 Tue May 22, 2012 10:13 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
