If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Posted: Mon Dec 09, 2002 7:14 pm Post Subject:
Re: Insulating walls
Battens are nomally 2x1 sawn but i prefer the use of polystyrene backed plasterboard. Have done my sitting room with east facing wall. Expensive but less work than drylining. Fix boards with special adhesive or builders foam(melts some backings) Sheffield Insulations can supply.
Joined: 18 Mar 2004 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Thu Mar 18, 2004 12:29 pm Post Subject:
Dry lining
I went to the Homebuilding & Renovation show at the NEC and saw some good products from Fermacell. They do a fibre board that doesn't need plastering; they make ready-mixed glue and joint filler that appear to require absolutely no special skill to apply perfectly. They also do adjustable metal battens to fix them to the wall that allow for the wall not being quite straight. Other makers may do these as well.
Joined: 09 Jul 2004 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Mon Feb 14, 2005 9:05 pm Post Subject:
I have recently used Fermacell to make a new ceiling in my bathroom. It was brilliant - much easier than plasterboard for a DIYer to put up.
A few tips -
- From the Fermacell website you can download a Handy Guide that is well worth reading before doing anything.
- For fixing, screws are easier to control than nails. Pre-drill the screwholes before offering up the boards.
- As with plasterboard, make a T-shaped prop to help put up the boards.
- If using the Jointstik to join the boards, use it very sparingly, because it oozes out of the joints and isn't as easy to remove as Fermacell say it is; when dry it is harder than the board and therefore difficult to sand down flush with the board.
- I didn't use the Fermacell joint filler because it also dries very hard and I expected the same difficulty sanding it down as I'd had with the Jointstik.
- If using the Fine Surface Treatment for a 'glass' finish before painting, apply it very sparingly. Don't try for a complete covering unless you are good at plastering. It is only meant to fill in the micro-pores on the board and any small gaps at the joints between the boards.
- The supplier in Bristol is the FGF Organisation, who were very helpful to me.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
