DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
new drain for Washing Machine
This topic originated from the How to page called Installing a washing machine
Click here to return to the page called Installing a washing machine.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
labob
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 22, 2007 12:52 pm    Post Subject:
Reply with quote Thanks
I want to move my washing machine from the front of the garage to the back. Unfortunately there is no drain at the back of the house near the garage. Can anyone give me any advice on building a drain. Is it an easy job to do or would I have to get a tradesman in (Plumber? builder?)
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
cudney
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 20, 2009 11:47 am    Post Subject:
there are a lot of regulations and test that must be carried out digging a new drain, can be quite costly. is there any way you could run a waste pipe down the inside of your garage to where the washer used to be? as long as you keep the right gradient and within in allowed lengths siphonage wont acquire and you'll save a lot of money.
if you use a 38mm (40mm) waste pipe the max length is 3 metres with a gradient of 18-90mm per metre.
i hope this helps
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Partially blocked drain from washing machine 2 860 Sat Sep 29, 2007 7:49 pm
Connect the drain of washing machine to boiler overflow pipe 9 320 Mon Nov 24, 2008 5:51 pm
BOSCH WFL 2260 washing machine won't wash, will drain 2 340 Sun Sep 07, 2008 7:31 pm
Hoover washing machine won’t drain - broken pump impellor? 4 2840 Thu Nov 24, 2005 12:37 pm
Removing front drain plug from Indesit washing machine 2 480 Sat Dec 29, 2007 6:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
