Joined: 22 Nov 2007 Posts: 6 Location: Northamptonshire, United Kingdom Thanked: 0 times
Posted: Thu Nov 22, 2007 3:06 pm Post Subject:
dual system
I live i an old ex council house (airey).
2 rads upstairs and 2 rads downstairs work on the front of the house, the 2 up 2 down at the rear dont, there is a new pump fitted, and the system is heated from a coal power back boiler, also when the heating is off one rad in the front bathroom still gets scolding hot, when the fire is lit. Please help.
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Thu Nov 22, 2007 3:32 pm Post Subject:
turn down the bathroom one. It may be offering an easy path for the flow of water, so stealing flow from other parts. And you say it is scalding hot too.
It is quite common to have a bathroom rad that is hot all or most of the time, this is good for drying towels, but unless you keep it turned low and/or have a TRV it is wasteful of energy.
Whenever you have a system with some hot rads and some cold ones, start by turning down the hot ones. If this cures it, Balance the Radiators (see info at top of this Plumbing Forum)
I live i an old ex council house -- heated from a coal power back boiler, also when the heating is off one rad in the front bathroom still gets scolding hot, when the fire is lit. .
That one is probably on a gravity loop to act as a heat sink.......you shouldn`t be able to turn it off well, you wouldn`t if I`d installed it cuz it`d have no valves the other ones that are hot can be shut as suggested....if it`s a steel panel rad like the others/modern ones....it won`t be on the hot water/secondary circuit......if it`s a heavy cast iron one , it probably is on sec . I wouldn`t worry about wasting energy from a coal fire ..........the heat`s got to go somewhere
Posted: Sat Nov 24, 2007 2:19 pm Post Subject:
central heating a pain
I turned the front ones of and the rear still dont work, Ive just added some sludge remover after drainig the whole system still nothing, they have been bled and bled till I felt hot water entering then they still dont work. ?.
Posted: Sat Nov 24, 2007 2:31 pm Post Subject:
what colour was the water when you drained?
if you bleed a bit out, what colour is it now?
If it has gone very black, that is the sludge being softened and washed away (which is what you want).
However if there are any area which are completely blocked, the chemical will not be able to circulate there If you have badly sludged rads, you can take them off and squirt them through with the hosepipe in the garden, but give the chemical a couple of days first.
When you bleed the rads, does water squirt vigorously out of all of them?
Have you got any thermostatic radiator valves? these sometimes jam shut.
Posted: Sat Dec 01, 2007 4:37 pm Post Subject:
I would just like to say thankyou to all who helped, all rads now working, just turned out to be the thermostatic valves, who would have thought all four would be knackerd, apparently the system has not worked for a couple of years, as I have only lived here for a couple of weeks, thanks again.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
