Joined: 23 Nov 2007 Posts: 7 Location: United Kingdom Thanked: 0 times
Posted: Fri Nov 23, 2007 11:43 am Post Subject:
One radiator is cold
I live in a tenement flat and have a system of 5 radiators throughout the flat. 4 of the radiators are very hot but one of the radiators is cold.
I have bled all radiators and still the problem persists. I don\\\'t know if this matters, but the radiator that is cold is furthest away from the boiler.
Any suggestions?
Edit:-
1) Boiler make / model (gas or oil) - Gas - Celsia F1
2) What is / is not happening - one radiator is not working
3) Has ANYTHING else been done or changed recently - nothing changed at all
4) When did the problem start? - about a week ago
5) When does it happen? eg, heating coming on or going off. - when the heating is turned on.
Posted: Fri Nov 23, 2007 1:46 pm Post Subject:
Sorry, I'm pretty clueless when it come to these things.
It looks like it has a TRV at one end (the knob makes it go hot and cold and notches run from 0 to 6) but not sure if there's a difference between a TRV and a valve. This is what I used to shut off the radiators (I turned them to zero).
Joined: 09 Feb 2006 Posts: 188 Location: Leicester, United Kingdom Thanked: 2 times
Posted: Fri Nov 23, 2007 1:55 pm Post Subject:
Ok well that bulbous thing that you turn the rad off with is a trv. Now what happens is they can shut off and then not re- open. There is a pin inside that operates up an down, opening and closing the valve. What you will find is that if you take the head off the valve the pin will be down and thus the valve turned off. So to rectify this push on the pin with pliers or a hammer, give it a few gentle taps and the it will pop back up and the rad will then work.
Joined: 24 Jul 2003 Posts: 18661 Location: London, United Kingdom Thanked: 62 times
Posted: Fri Nov 23, 2007 4:43 pm Post Subject:
POst a pic if it has no make on it. If we can recognise it and you can get one the same and swap the head, you won't need a nasty expensive plumber, or get wet yourself
Joined: 02 Dec 2007 Posts: 1 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Sun Dec 02, 2007 2:57 pm Post Subject:
Hi
I've had a similar problem, thank god I found this site! It turned out to be TRV head which was broken. The head on there at the minute is made by Myson - do I have to replace the head with another Myson, or will others work - any plumbers recommend some good value ones available online?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
