DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Plug fuse vs Consumer unit fuse
This topic originated from the How to page called Changing a fuse on the consumer unit
Click here to return to the page called Changing a fuse on the consumer unit.
  View previous topic :: View next topic
Author Message
mark19
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 23, 2007 7:20 pm    Post Subject:
Reply with quote Thanks
Could somebody explain why a plug fuse should not be used in place of a consumer unit fuse for a lighting circuit (5amp). In other words, what is the difference between a plug fuse and a consumer unit fuse. Many thanks for your replies.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Nov 23, 2007 7:29 pm    Post Subject:
afaict the main issue is that it is a bit oversized and so will put strain on the carrier.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 10 times
PostPosted: Fri Nov 23, 2007 7:33 pm    Post Subject:
Plug fuse is to BS1362, consumer unit fuse is to BS1361
1) Slight difference in size firstly, could lead to a bad connection
2) Different fusing factor, somwhere between 1.6 and 1.9 for a plug fuse, needs to be 1.45 or less for consumer unit fuses unless we want to start applying extra factors to check compliance of the wiring (as we do with 3036 fuses)
3) different breaking capacity, a BS1362 isn't garenteed to break anything above 6ka, if BS1361 fuses were used because of a high PFC then not a good idea to fit something with a lower breaking capacity
4) Anyway the board was designed for BS1361 fuses, anything else won't have been type tested with it. etc, etc
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Nov 23, 2007 7:41 pm    Post Subject:
playing devils advocate for a bit.
I will assume we are talking about 5A fuses because those are the only ones that are reasonablly close in physical size between the two types. That means lighting circuits and those tend to have plenty of slack for such correction factors.
True but assuming this is a domestic situation the service fuse should be providing adequate back up protection.
it's a bodge but IMO it is not a particularlly dangerous one.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Nov 23, 2007 8:27 pm    Post Subject:
I have a feeling he is thinking about the price difference.
Another prob is that plugtop fuses also come in 13A which would be undesirable on a lighting circuit.
Back to top
 Alert Moderators
kai
from United Kingdom
Thanked: 5 times
PostPosted: Fri Nov 23, 2007 8:57 pm    Post Subject:
Price difference.
The best way round that is to replace the 5amp holder in the CU with a 15amp one, with a length of 2.5.mm cable from the 15amp fuseway to a fuse-connection unit next to the CU, then the wiring for the lighting circuit starts from the FCU, with a 5amp plug fuse in it - my lighting was done like that in a former home - solves all problems. icon_lol.gif icon_lol.gif icon_lol.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Converting old Fuse type consumer boxes to plug in mcb's 13 3020 Wed Dec 06, 2006 5:34 pm
microwave plug fuse 3 160 Sun Jan 11, 2009 2:41 pm
Plug Fuse for Compressor 8 520 Wed Dec 06, 2006 5:06 pm
13 Amp plug fuse 20 840 Mon Aug 13, 2007 2:39 pm
Plug fuse or cartridge fuse 15 800 Fri Oct 13, 2006 12:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
