DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Cold Rads Downstairs
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
pers5579
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 2:09 pm    Post Subject:
Reply with quote Thanks
I have a Combi (Puma) Boiler. Hot Water is fine. Pump replaced last month. All Upstairs rads are RED HOT, All downstairs rads are STONE COLD. The system has been drained and refilled, All rads are balanced. Flow pipe is very hot, return pipe is cold. Pump is definately ok.
Someone suggested a possible air lock in the pipework - how would this be resolved?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
corgiman
from United Kingdom
Thanked: 2 times
PostPosted: Sat Nov 24, 2007 2:42 pm    Post Subject:
try turning off all the rads that work see if you can force it round
do they have thermostatic rad valves?
__________________
If at first you don't succeed, remove all evidence you ever tried.
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 3 times
PostPosted: Sat Nov 24, 2007 2:44 pm    Post Subject:
Shut off all the rads barring one downstairs rad. When that one gets warm open the next and shut the last one off. Go round your system like this.
If you find a rad or two stops working then your system needs balancing.
__________________
Eagles may soar high but Slugs" don't get sucked into jet engines
Back to top
 Alert Moderators
pers5579
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 26, 2007 2:31 pm    Post Subject:
Hi all,
Some of the Rads have TRVs others do not. I have shut off all the Rads except 1 downstairs - it gets luke warm - thats all.
I have tried this several times and still have the same problem - any other suggestions?
Back to top
 Alert Moderators
hi-spec plumbing heating
from United Kingdom
Thanked: 0 times
PostPosted: Mon Nov 26, 2007 2:35 pm    Post Subject:
is that fitted with a trv ?
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 3 times
PostPosted: Mon Nov 26, 2007 11:30 pm    Post Subject:
pers5579 wrote:
Hi all,
Theres got to be some form of blockage in that circuit then. Probably a blocked manifold but could be anywhere. Blockages usually occur near fittings and bends. Rarely on straight bits of pipe.
I would take the radiator off, flush it out and then run water through both rad valves.
__________________
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 188 times
PostPosted: Tue Nov 27, 2007 11:09 pm    Post Subject:
Airlock in a sealed system is very unlikely, probably just full of c-rap
__________________
Don't feed the troll.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cold Rads Downstairs 3 2260 Wed Oct 26, 2005 9:08 am
cold rads downstairs 2 1600 Fri Dec 10, 2004 5:33 pm
CH woes - cold rads downstairs 3 640 Sat Jun 24, 2006 8:25 am
Cold Rads Downstairs 8 3580 Fri Oct 26, 2007 8:12 am
downstairs rads cold, replaced pump still no CH 6 700 Sun Sep 30, 2007 4:46 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
