DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fuse/Cable Relationship
This topic originated from the How to page called Converting a radial circuit to ring circuits
Click here to return to the page called Converting a radial circuit to ring circuits.
  View previous topic :: View next topic
Author Message
yushoo
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 09, 2004 6:46 am    Post Subject:
Reply with quote Thanks
icon_question.gif I have used a redundant 6mm shower cable to supply power to a new immersion heater. The cable was protected in the CU with a 30A breaker. Should I reduce this and if so to what?. Also would it be advisable to install a switched fused spur to isolate power to the digital immersion timer. Any help appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 09, 2004 7:15 am    Post Subject:
So long as the redundant cable is sound and has the required insulation resistance and cpc ('earth') continuity it should be usable. (are you able to check these?) Your circuit protective device should be rated larger than the design current (the current drawn by your immersion heater) and smaller than the current-carrying capacity of the cable. A 30 A breaker suggests it's either a BS3871 or a plug-in fuse replacement. If it's the former you may find it impossible to replace, but a 6mm cable should carry more than 30A in most domestic situations so you can leave that as is. (Although, ideally, you'd replace it with a breaker closer to your design current.)
You should have local isolation at the business end. A fused connection unit not only gives you local isolation and fusing, it also allows you to de-rate and connect the heat-resistant flex you'll no doubt be using between the fcu and the immersion.
(If in doubt, get somebody to check it all out for you professionally)
Back to top
 Alert Moderators
yushoo
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 09, 2004 8:03 am    Post Subject:
Thanks dingbat for the quick reply. As you suggested the breaker is a plug-in fuse replacement. Will follow your advice and thanks again for your help.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
ZE & PFC Relationship 7 240 Fri Feb 06, 2009 6:34 pm
10.4KW Cooker to 30A Fuse box? 6.mm cable Okay? 15 1040 Mon Oct 23, 2006 3:18 pm
Fuse and cable for a cooker 14 660 Wed Aug 10, 2005 9:15 am
Lighting cable switch and tripped fuse 4 420 Wed Dec 08, 2004 1:49 pm
shower cable and fuse 2 420 Fri Jun 08, 2007 3:28 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
