DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Double oven kitchen wiring - check
This topic originated from the How to page called Installing an electric cooker
Click here to return to the page called Installing an electric cooker.
  View previous topic :: View next topic
Author Message
Plakias
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 25, 2007 8:19 am    Post Subject:
Reply with quote Thanks
Hi guys,
I am about to change my single electric oven for a double one and want to check that everything is ok.
In the terminal box, I have a cooker breaker (50Amp), from there, a 6mm armoured cable (10 meter along the outside wall to the kitchen) going to the control unit in the kitchen – this is 45Amp rated.
From there, it goes behind the oven to a split box where it feeds the electric hob and the oven.
Electric hob is around 7.2 Kw.
Double oven will be around 5 Kw (the current single oven is less).
Total: 12.2 Kw, which ask for 50.8 amp in full load.
Is it ok to connect as it is or do I need to upgrade the consumer unit in the kitchen?
Seb
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Sun Nov 25, 2007 7:14 pm    Post Subject:
Have your electrician change the MCB (breaker) for a 40 amp one. 6mm SWA can rarely (if ever) carry 50 amps, and the CCU (cooker switch) is only rated to 45 amps, as you say.
And your cooker will rarely need 40 amps anyway, never mind 50 (all its elements cycle on and off on thermostats!)
By the way, normally a single oven will plug into a standard socket like a kettle does.
Back to top
 Alert Moderators
Plakias
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 29, 2007 1:08 pm    Post Subject:
Thanks Steve, very useful - I'll do that!
Cheers
Seb
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Double check my cable calcs please? 22 1920 Fri Aug 17, 2007 4:02 pm
Oven & Hob rewiring : a sanity check 6 1160 Thu Nov 11, 2004 5:01 pm
Free wiring & fuseboard safety check ! 7 400 Sat Aug 22, 2009 11:41 am
4 Downighters replacing single light, check wiring please 2 460 Mon Oct 30, 2006 7:29 pm
Old house - poor wiring - elecs need "health check" 5 260 Mon Jul 06, 2009 1:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
