been workin on a baxi 105e today which needs a new calorifier (not transferring the heat) what i was wondering is do they have a return filter and where exactly is it? is there one in the return isolation valve or the manifold? thought it mite be a idea to check it!
iam guessin theres muck lining the inside of the "plate to plate heat exchanger" effecting the heat transfer. so if there's muck in that they maybe muck in the system and while its drained i might aswell check the filter
