DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Can a 150w PIR light be upgraded to a 300w
Author Message
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Fri Nov 30, 2007 9:21 am Reply with quote
Hi guys
I purchased the following outside light a couple of months ago
https://www.screwfix.com/prods/99280/Lighting/Floodlights/Controlled-Floodlighting/IQ-Hi-Lo-PIR-Floodlight-150W
I am now wishing I had opted for the 300w version. Can I just upgrade the bulb to a 300w or will there be some internal differences?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1468 times
PostPosted: Fri Nov 30, 2007 9:25 am Reply with quote
no, the tube is bigger.
Back to top
 Alert Moderators
garrymum
from United Kingdom
Thanked: 5 times
PostPosted: Fri Nov 30, 2007 9:27 am Reply with quote
What, the 300w bulb is actually bigger? The once I have been looking at are both described as 80mm tubes available in 150 / 300w
Back to top
 Alert Moderators
Chri5
from United Kingdom
Thanked: 362 times
PostPosted: Fri Nov 30, 2007 9:40 am Reply with quote
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 460 times
PostPosted: Fri Nov 30, 2007 4:39 pm Reply with quote
Even if you found a 300W linear tube that would fit, the fitting is only rated to 150W.
Problem...
Back to top
 Alert Moderators
Trog
from United Kingdom
PostPosted: Fri Nov 30, 2007 6:29 pm Reply with quote
Page 9 of the manual for the lamp as linked from the Screwfix web page says it will take a 300W R7S bulb.
Back to top
 Alert Moderators
soaringjock
from United Kingdom
Thanked: 2 times
PostPosted: Fri Nov 30, 2007 10:06 pm Reply with quote
USURE?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 460 times
PostPosted: Fri Nov 30, 2007 10:12 pm Reply with quote
There are two models listed in that spec.
The 150 model will take 150W. The 300 model will take 300W.
Which have you got?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1468 times
PostPosted: Fri Nov 30, 2007 10:25 pm Reply with quote
on the lamps I've used, the 300W and the 500W are the same size, and the 150W is smaller.
Go and have a look in a shop to see.
Back to top
 Alert Moderators
Trog
from United Kingdom
PostPosted: Fri Nov 30, 2007 10:46 pm Reply with quote
You are right I took the code numbers to be the order numbers for the bulbs, but on reflection they are for two versions of the lamp. Note 2 in particular would be way clearer if they had added 'depending on which model you have' to the text.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
old consumer units need to be upgraded? 6 560 Fri Apr 13, 2012 1:18 am
Do I need an electician when having the en-suite upgraded? 6 160 Mon Jan 17, 2011 7:27 pm
Electric meter being upgraded by DNO 9 880 Sat Jun 02, 2007 1:02 am
Upgraded supply for a new shower? 8 180 Tue Jan 15, 2013 1:25 pm
Do I need this upgraded first?? 26 1800 Thu Feb 28, 2008 10:00 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
