Redhotferrari
Joined: 11 Sep 2007 Posts: 578 Location: United Kingdom Thanked: 8 times
Posted: Sun Dec 02, 2007 5:56 pm |
Hi Guys,
Complete newbie at wood flooring, but want to wood floor my toilet room, which is seperate from bathroom, so as you can imagine pretty small area!
I am going to remove the toilet completely for the project so it looks better, however the soil stack comes out of the ground behind the toilet.
Any tips/advice on making a template to match the shape and cutting the wood?
Cheers |
mattysupra
Joined: 30 Jan 2007 Posts: 2154 Location: West Midlands, United Kingdom Thanked: 45 times
Posted: Sun Dec 02, 2007 7:07 pm |
well i think you have answered your own question.....
A template! Use paper. Many different ways to do it but if you use paper and then transfer it to the wood. I like to template the whole area as one if a small area. Next put the flooring together and place the template of the whole area on top of the laminate. Simple. |
topgazza
Joined: 19 Apr 2004 Posts: 279 Location: Hampshire, United Kingdom
Posted: Sun Dec 02, 2007 11:38 pm |
Paper template every time. Still allow 10mm around the soil pipe for expansion. I then use silcone bathroom sealant to fill the gap....they do various colours now including a couple of browns |
Redhotferrari
Posted: Mon Dec 03, 2007 7:13 am |
Thanks for help so far, one more question.
Whats the best way to tackle door frames when it comes to Laminate floors, dont really want to them off if I can help it. Also plan to leave the skirting boards on, and use edging strips, is this a bad idea?
Cheers |
joe-90
Joined: 28 Oct 2005 Posts: 26215 Location: United Kingdom Thanked: 788 times
Posted: Mon Dec 03, 2007 8:54 am |
I ALWAYS take off the skirting. It looks absolutely amateur to do otherwise.
As far as the frame goes, most people use a fine toothed saw to take off an amount that will allow you to slip the laminate underneath.
However, if you have floorboards | personally think they look a thousand times better than laminate. |
topgazza
Posted: Mon Dec 03, 2007 10:45 am |
Definately take the skirting off...it looks so much neater and even if you have to replace the skirting board because of damage with some nice ogee type you can stain and it then compliments the flooring. Be cheaper than that edging stuff thats for sure. The extra hassle is well worth it....
Possibly one of the reasons a lot of folk go for laminate, especially in newer houses, is the thickness. Wood flooring is superior but is usually too thick when it comes to doorways and the rooms adjoining it. It becomes almost a step..... |
