Vokera Linea 24 - 03 fault - not in forum so far!
2 Jan 2007
London
Hello there, my Vokera Linea 24 is coming up with an 03 fault. The fan does not spin, nor is there power to it and the boiler does not ignite. I cannot reset it.
Although another part of the forum mentions someone else who had an 03 error, his fan was running - mine is not. I have checked the flue and this appears clean, so i'd like some advice, please.
Thanks - Phil
You need to sort the reset problem first.
When you turn the knob to the middle does the display go blank?
If not the knob has snapped off inside.
After you manage to reset it see what happens.
(i think turning the power off for a short period will reset it also)
If no power to fan on ch or dhw I would suspect the pcb has gone, or at least the fuse on it.
Many thanks to all who replied - and yes, you were all correct - it was the PCB. I managed to find a second hand one on E-bay but it has been that cold that i went and bought a new one, which did the trick.
Unfortunately, it was nothing as cheap or as simple as a fuse. And it seems a shame to throw the old PCB away.
Does anybody know who fixes these PCB's? I can repait to component level myself but without a diagram or a test jig - or a spare installed Linea 24...!!!...i cannot repair it as is.
Thanks once again to all who replied. I am now no longer one of the great unwashed!!!
Regards,
Phil.
