quyen
Joined: 15 Jul 2004 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Jul 15, 2004 11:56 am Post Subject: where is the temp control |
I can\\\'t find where the temperature control is for my immersion heater! I\\\'ve removed the insulation around the boiler and checked on the timer control. My hot water gets very hot to around 90 Celcius. Anyone any ideas? |
masona
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Thu Jul 15, 2004 12:08 pm Post Subject: |
Post this in the plumbing section for a quicker reply. |
IanDB
Joined: 26 Nov 2003 Posts: 750 Location: Dorset, United Kingdom Thanked: 0 times
Posted: Thu Jul 15, 2004 3:18 pm Post Subject: |
Switch off the supply and remove the round plastic cover of the immersion heater. You will see a small black plastic terminal block that normally has a small adjustable screw for the temperature. Mind you, if everything was working OK before hand there's a good possibility that your thermostat has packed up.
This http://www.diynot.com/forums/viewtopic.php?t=8826&highlight=immersion+heater+wiring post has a picture included. __________________ Never assume tomorrow will get better |
