Following a slight DIY accident of slicing through part of two alarm cables - one for PIR, the other for the keypad terminal. I've cut the offending sliced areas, re-routed slightly to give me the slack to work with and then used a proper junction box to join.
However, having done this the keypad terminal is lifeless. I'm wondering whether I've blown a fuse as i didn't cut the power before I cut through the main cable....?!?
Have I done anything wrong? or is there I need to reset etc....? I can get the make/model of alarm system tonight, if required.
Thanks in advanced. David
