DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Semi pedestal and pop up waste to fit
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
tel3563
from United Kingdom
PostPosted: Sun Dec 09, 2007 2:42 pm Reply with quote
Hi all, have bought basin with semi ped, no instructions just some fittings and some springs, can anyone explain in detail (simple detail icon_smile.gif ) how on earth i fit this to the basin, also the same applies to the pop up waste supplied with the mono hole tap, no instructions again, a diagram of both would be fantastic if possible icon_mrgreen.gif , I thank you in anticipation, t
Back to top
 Alert Moderators
mmm80
from United Kingdom
Thanked: 1 time
PostPosted: Sun Dec 09, 2007 8:05 pm Reply with quote
loop end of spring fits over basin hanger bollt, secured with nut and washer.
unscrew plastic sleeve to stop.
offer up semi ped, insert hook end of springs, tighten with plastic sleeves
Back to top
 Alert Moderators
tel3563
from United Kingdom
PostPosted: Mon Dec 10, 2007 12:10 pm Reply with quote
Thanks mmm but don't understand unscrew plastic sleeve to stop.
Back to top
 Alert Moderators
mmm80
from United Kingdom
Thanked: 1 time
PostPosted: Mon Dec 10, 2007 6:28 pm Reply with quote
do you have two springs with a loop and hook? well the plastic sleeve over spring, turn anticlockwise as far as you can
Back to top
 Alert Moderators
tel3563
from United Kingdom
PostPosted: Mon Dec 10, 2007 11:20 pm Reply with quote
Have the spring with hooks but don't seem to have a sleeve, where would this sleeve go on the spring and what would it look like
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
semi pedestal waste pipe 2 440 Sun Feb 07, 2010 8:39 pm
Longer fixing bolts for semi-pedestal basin. 3 640 Fri Jan 02, 2009 5:32 pm
Semi Pedestal how to re hang 3 780 Sun Aug 31, 2008 5:51 pm
Bathroom suite for a Victorian semi 3 160 Sun Aug 14, 2011 11:29 am
Temporary/Semi-Permanent removal of Radiator - no drain down 8 100 Mon Nov 07, 2011 12:10 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
