MICROBORE WITH CONDENSER BOILERS
15 Dec 2007
Yorkshire
Hi
i have a 8mm microbore central heating system that is run by a very reliable potterton 25 years back boiler, However it is not that economical and i wonder if it will last Would it be possible to install a condenser/combi to run with the microbore as the access to pipes would be a right pain with tiles /laminate i have been told that when the back boiler expires, touch wood, i will not be able to replace with a back boiler
.Any advise for starters to educate
thanks Pat
There are no problems doing this, apart from the fact that Microbore cannot be successfully cleansed using a powerflusher.
My company now recommends a Magnaclean or similar magnetic particle trap to be fitted in such situations.
You will need to resite a wall hung boiler and this may lead to issues with your laminate floor, but there is no substitute for seeing the job so I suggest inviting quotes from a couple of local reputable companies.
i also have twin entry ( maxitwin valves fitted ) would they be alright . i have no TRV,s fitted
Maxitwins make no odds. You will have a job fitting TRVs to these but it possible.
thanks SIMOND
so to sum up i can run a microbore system on a combi using the crap remover you suggest and dont need to have TRV . Sorry to be a bit finnicky .just want to be prepaired
Under building regs you should have TRVs in sleeping areas but with maxitwin this is difficult.
All I can say is that we put a disclaimer in our quotes under these situations. With certain rads you can extend the 8mm and use two conventional bottom entry 8mm valves but this is way beyond the call of duty :lol:
