benjiman
Joined: 21 Jul 2004 Posts: 157 Location: United Kingdom Thanked: 0 times
Posted: Wed Jul 21, 2004 9:27 pm Post Subject: Spotlights - One comes on first then another?! |
Hello all,
I have just re-done the wiring for the lighting circuit. I have added two spot lights in the sitting room - these are controlled by one switch.
However the problem is that when I turn them on, one comes on first and then a few seconds later the second one comes on!
Is there anything wrong with the circuit why is this happening?! On the same circuit I have another pair of spotlights located in the porch. They also operate from one switch. When I turn them on they both come on together. Why are the sitting room ones not coming on together!?
Please help. |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Wed Jul 21, 2004 9:39 pm Post Subject: |
you havent said if they have transformers
i should assume they have transformers, either bad connection, faulty transformer or switch __________________ Do you like music Mr Finch?
Forum = Opinions |
benjiman
Posted: Wed Jul 21, 2004 10:00 pm Post Subject: |
yup they have transformers.
Thanks for your help breezer - Bloody heck! Simple things like that didnt even occur to me! I was completly brain dead.
1st job of the day tommorow will check all connections on switch and then spots.
Cheers mate  |
benjiman
Posted: Wed Jul 21, 2004 10:05 pm Post Subject: |
1st job of the day tommorow will check all connection on switch and then spots.
Cheers mate  |
benjiman
Posted: Thu Jul 22, 2004 12:00 pm Post Subject: |
Checked switch - all ok.
Then went to check connections on the spots and the one that came on after a few seconds had a dodgy transformer! One of the wires had come loose.
So put new transformer in and everything working fine!
Thank you once again breezer - Top man! - cheers!  |
