Toilet not flushing corectly
16 Dec 2007
Cambridgeshire
Hope someone can help me here.
I keep getting problems with my upstairs toilet not flushing, this then slows the drainiage of my bath as well.
I have rodded the pipes and they are all clear of blockages.
What I did notice is that when I removed the vent from the large drainage pipe. The toilet cleared instantly, it hen flushes with no problem.
As soon as I put the vent back on I get the same problem.
Does this mean the vent is broke?
Or do I have another problem some where else?
Your help would be much apreciated. :LOL:
i'm not sure mate. The toilet conects to a pipe about 6 inc diameter. This pipe goes down to the drains, it also goes upwards. In the top there is a plug with a vent in it, its like a big bung with vents all oaround it. When I take that out it flushes properly.
Thanks for your help.
Sounds like an air admittance valve and it also sounds like it isn't admitting air!
Does it look like this?:
If everything is OK with it removed then a new one should solve your problem.
Hi brought new air admittance valve, installed. However I still have the problem until I take it out. Do I have to do anything after I have install it?
Regards
Mazda28 :oops:
sounds like it was OK all along :oops: The valve itself, that is .........there must be something wrong with your soil/vent setup :confused: could be anything tho` :oops: maybe positive pressue build ing up :idea: because an AAV only lets air IN under negative pressure....long shot , it might be a blockage somewhere on the underground drain run.
Perhaps you should not have a sub stack. Your property should be served by a soil and vent pipe open to atmosphere although it can be shared with a neighbour in some cases.
Do you have one?
