Hello,
We've recently moved into a new (old) house with a CH system fitted by BG approx 4 years ago. We've had issues with it since we moved in, namely -
1)Radiators not getting hot in some rooms, with others getting to about the temperature of the sun(!).
2)The boiler would cut out (or fail to come on when the timer came on) but would light up every time if it was reset. If the heating was on all day, it was having to be reset perhaps ten times.
We had a BG engineer out to look at the system on Thursday (it's under a 5 year BG 3 star warranty) who replaced the system pump and (I think) balanced the radiators. This improved things in greatly until this morning. The CH and HW came on as normal, when they went off at 8:30 (as they should - on the timer) I set the system to 'once' (on all day) and the boiler went off and I haven't been able to get it to relight since.
The timer seems to be working, the lights come on and go off as they should, the pump runs and the stats both click when turned (second stat in the garage where the boiler is to protect from frost).
Everything seems to be working except the boiler. When I cycle the reset switch there's an audible relay click but no fan (or other) noise. A few seconds afterwards there's another relay click. Other than that, no signs of life although you can hear water moving in the feed and return pipes.
I've taken the outer casing off to check for obvious problems but there's nothing out of place that I can see.
I turned the boiler and the power feed to the timer off and left it for a couple of hours (standard IT procedure!) but it hasn't made any difference.
BG can't send out an engineer until Monday so we're stuck with the prospect of no CH or HW until then. Is there anything you learned ladies/gents can suggest that I do to kick start the bugger in the meantime?
Thanks in advance.
Mike.
Thanks in advance.
Mike.
