DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
subsidence and a crap insurance company
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  Bookmark and Share View previous topic :: View next topic
Author Message
flipper1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 31, 2007 3:47 pm    Post Subject:
Reply with quote Thanks
After decorating most of my home and now seeing most of whats done crack and move, i'm now caught in a battle with my insurance company about subsidence. They have sent round a surveyor(my mum could have done a better job) who looked at my property over a year ago and the reccomendation was to fill the cracks and regrout tiles etc.. a year later the problem is 20 times worse serious movement so they take out a large tree and then issue me with a plan of works. Which obviously falls well short of what i want done. And now there is a problem with my upstairs bay window. The insurance company say that the movement to this is down to lack of support in the new windows - and the weight of the new windows. I've still got 2 years left on a warranty that I inherited when i brought the property but i will have to change over the details.
can anyone offer some advice on my next step. should i let the insurance and window people fight it out and how can i get maximum repair work for my £1000 excess - any help is most welcome!
Happy new year!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
EdSet100
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 01, 2008 1:26 am    Post Subject:
You don't pay a £1,000 as some sort of payment to get the maximum repair work out of them. You pay the £1,000 only as part of the costs of repairs due to subsidence, which can run into many thousands of pounds. The £1,000 is not there to sort out some cracks around your house, which can be caused by any number of things.
The bottom line is this: has the surveyor actually confirmed that you have subsidence? Subsidence is movement of the ground, causing the building to move, and not the building (heavy windows) causing part of itself to move. Therefore, the assertion that the windows are causing more cracks is irrelevant unless you do not have subsidence.
Your insurance company's surveyor's first action should have been to engage an engineer to excavate an area close to your foundations by the cracks to determine if the ground is stable by examining stratae and underground channels caused by water movement or collapse caused by moisture removal due to trees, etc. If there is no evidence of subsidence, your claim has reached its conclusion and you get to keep your £1,000. If there is evidence of subsidence, you put £1,000 into the pot and the surveyor will commission tradesmen to mitigate against further movement (remove trees, fix drains, etc), or if mitigation is impossible, engage specialists to underpin to the bedrock below the troubled strata.
The issue of heavy windows is entirely another possible cause of other cracks which is not a claim for subsidence and therefore might not require you to stump up the excess of £1,000. It will be up to the insurance company surveyor to determine if the cracks are caused by damage through negligence or accident and to then pay for the repairs. If they can find the party responsible for causing the damge thats their problem to resolve. In the meantime they have an obligation to you to repair the cracks
Back to top
 Alert Moderators
imamartian
from United Kingdom
Thanked: 34 times
PostPosted: Tue Jan 01, 2008 1:40 am    Post Subject:
sell the property as is?
we're at the peak of a house price bonanza.... what you get could buy you a whole lot more in 12 months?
Back to top
 Alert Moderators
memor maplin
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 30, 2008 6:55 pm    Post Subject:
The Large tree sounds mature so it wouldn't have been that much of a problem.
Now the tree has gone the moisture it sucked up (considerable) has no where to go so in the winter you'll get heave. This causes cracks.
They should have trimmed it back first. Then left it a year before completely removing.
The best way to get action is to phone the insurance company every day. If the Agent suddenly is out or in a meeting phone his manger and go up the chain of command till you get satisfaction.
Its the ones who make a pest of themselves that get anything done.
Back to top
 Alert Moderators
Joe Malone
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 09, 2008 1:55 pm    Post Subject:
This whole case sounds a little strange to me.
Am i getting this right? First they tell you you've got nothing more than settlement cracks above windows due to inadequate support. I'm assuming the windows have been changed at some point from timber to UPVc.
When the movement continues they cut down a tree without any further investigation?
The first course of action in these cases is always to establish whether the movement is static or dynamic and that must be done by using tell tales or stainless steel studs on the cracks. These are measured for movement every month for at least six months, ideally a year. Settlement cracks above windows are pretty obvious and what you're looking for in cases of subsidence is some degree of rotational movement of a proven dynamic nature. When this has been established then you would start further invasive examinations such as digging trial pits or soil analysis.
It isn't sensible to cut down a tree which is linked to subsidence problems. The starting point would be to pollard the tree back then continue crack monitoring to establish what effect this is having.
It doesn't sound as if the basic sensible steps have been taken in establishing the cause of your problem or managing the situation.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 70 times
PostPosted: Sun Mar 09, 2008 2:18 pm    Post Subject:
Joe you are missing the point. "Sensible" and "insurance company" do not go together at all, and its bad grammar to use both in the same sentance
Back to top
 Alert Moderators
Joe Malone
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 09, 2008 2:44 pm    Post Subject:
Woody, you're such a cynic!
Back to top
 Alert Moderators
andy2306
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 09, 2008 5:20 pm    Post Subject:
Building costs up 27%!!!
All the best builders down in london building for the olympics!!
House prices are unlikely to fall much if you factor these 2 facts in, Infact its more likely to remain bouyent!!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
WALL IS CRAP 18 10580 Sat Sep 25, 2004 2:11 pm
Getting to a Builders Public Liability Insurance Company 4 280 Wed Dec 09, 2009 12:13 pm
BUILDINGS INSURANCE : SUBSIDENCE CLAIM 4 1020 Wed Sep 24, 2008 7:48 pm
Water Company problem with Flat Drainage - Advice Please 2 380 Thu Jan 19, 2006 8:31 pm
Recommendation for a conservatory company in Bury, Lancs? 3 500 Mon Sep 25, 2006 11:36 am
DIYnot
