Joined: 28 Jul 2004 Posts: 8 Location: United Kingdom Thanked: 0 times
Posted: Wed Jul 28, 2004 4:00 pm Post Subject:
Old and New Wiring
Hi
I am renovating an old apartment (1970's) whose walls floors and ceilings are all poured concrete, making access to wiring next to impossible. I have three radial socket circuits, one for each room, all with 20Amp fuses but using old red and black wiring (not sure of the size/rating). Can I connect the required 2.5mm wiring where they enter the room and rewire from there, or do I need to tear down to whole apartment and replace the 5m of old wire which connects to the cu.
Joined: 25 Jan 2004 Posts: 6315 Location: Vatican City State Thanked: 0 times
Posted: Wed Jul 28, 2004 4:07 pm Post Subject:
I believe the issue with old wiring is that the insulation breaks down rather than anything else. Provided the insulation is doing its job within current tolerances then it is OK to leave it, I think.
There is, however, the issue of where you connect to the old cable. If this is done at an accessible point such as a plug socket or junction box then it is ok. What you can't do is use a standard junction box and then bury that in the wall.
Joined: 27 Aug 2003 Posts: 21988 Location: London, United Kingdom Thanked: 78 times
Posted: Wed Jul 28, 2004 5:22 pm Post Subject:
Re: Old and New Wiring
I can't work out what you want to do, and why..
If you think that the place needs rewiring, why are you thinking about only replacing part of each cable?
If you don't think it needs rewiring, what is it that you want to do to the circuits?
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Joined: 11 Jan 2004 Posts: 16485 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Wed Jul 28, 2004 11:36 pm Post Subject:
You call 70's old!!??
In theory, pvc T & E has a lifespan of 30-35 years, but having said that, VIR is very much still alive, and in some cases, well in many houses, having been installed in the fifties.
So, judging by that, I reckon that pvc will outlive rubber, but who knows?
70's should be OK - pvc and solid conductors, but if you have stranded conductors then you may need a full rewire, especially as a lot of 60's cable was not pvc, but ashathene. not sure of spelling.
Posted: Thu Jul 29, 2004 10:25 am Post Subject:
Thanks for all your input!!
Plug - I neglected to mention I was living in Ireland where I believe the wiring was changed years ago. Not 100% sure when......
Ban - The existing wiring for the sockets was all over the place, so I basically want to relocate and add sockets to each ring circuit. The easiest way to do this would be to completely rewire all the sockets. However, the wiring from the CU to the first socket was buried in the wall and I was wondering if I could use this existing wire from the CU to the first socket and then new wire for the rest of the sockets!! - Hope that makes sense, though I think Adam worked it out first time
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Thu Jul 29, 2004 4:40 pm Post Subject:
if the cable is pvc and not rubber then it should be ok (though it may be an idea to get it tested)
also i don't know what the irish regs are on marking the intersection between old and new colors. i think there are some irsih sparkys here who culd advise more on this
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
