DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
fencing repair
This topic originated from the How to page called Erecting a fence
Click here to return to the page called Erecting a fence.
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
  View previous topic :: View next topic
Author Message
johnvv
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 30, 2004 3:12 pm    Post Subject:
fencing repair
Reply with quote Thanks
I have a 4ft high fence with concrete posts and would like to replace them with a 6ft fence. It seems to much work to replace the concrete posts. Can I just put the new fence panels in and then put a piece of 3x3 wood post above the concrete posts. Most of the panels are hidden behind scrubs. Will they be strong enough
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Jul 30, 2004 3:52 pm    Post Subject:
without knowing how deep the concrete posts are its hard to say
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
johnvv
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 30, 2004 3:59 pm    Post Subject:
The concrete posts are about 1ft in the ground and you cant move them. Thats why I dont want to get them out. Far far too much work.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Jul 30, 2004 4:03 pm    Post Subject:
6:1 hmmmmm 6:2 is ideal
__________________
Forum = Opinions
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Jul 30, 2004 4:36 pm    Post Subject:
Shouldn't be too difficult if there're 1ft in the ground and should be at least 2ft in the ground, so really best to take them out. If you hose the post holes down with plenty of water then lever backward & forward which should work it way loose. If you use 6ft panel with the 4ft posts you will then have a greater area wind span putting pressure onto the posts.
Back to top
 Alert Moderators
david and julie
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 30, 2004 5:08 pm    Post Subject:
People sometimes put 2ft of lattice on the top instead, would that be any good?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Jul 30, 2004 5:14 pm    Post Subject:
It would but depend how much privacy johnvv want.
Back to top
 Alert Moderators
mildmanneredjanitor
from Hong Kong
Thanked: 0 times
PostPosted: Fri Jul 30, 2004 5:32 pm    Post Subject:
__________________
Could it be Rosemary - the telephone operator?
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 24 times
PostPosted: Sat Jul 31, 2004 11:18 pm    Post Subject:
couple of points to note if you put six foot panels up
you increasing the area for the wind to hit by 30%
not only that the fence panels will have to support
the post extensions so in effect your asking your
top post fixing to support nearly half the pannel
plus the added bit of post
i think if your trying to cut corners you may
have to do it properly in ayear or two as things
good luck with what you choose anyway
__________________
big all
we are------------------ all still learning
Back to top
 Alert Moderators
johnvv
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 02, 2004 5:57 pm    Post Subject:
Thanks for all replies. The wind problem is what Im worried about. Once I have got the panels out, I will have a look to see how secure the posts are. Ive been told to hire a kangol to dig out the posts, but everyone at work saids its too much work. Will report back soon
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
Decking - rot repair 2 360 Fri Apr 06, 2007 7:58 pm
Wooden fence posts repair? 3 2080 Sat Mar 10, 2007 3:49 pm
Repair gate post 5 580 Mon Aug 22, 2005 12:34 pm
repair of concrete posts 2 480 Mon Jan 31, 2005 9:59 am
Mossy grass-repair or replace? 8 660 Mon Jun 18, 2007 11:34 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
