Quiet ballvalve problem
321
3 Jan 2008
Devon
Hi.
I have a problem with the Quiet ballvalve on the toilet. (3 years old)
I flush the toilet and the water continues when cistern is full,
Even when i hold up the little arm valve!
It started to day when flushed.
Are there any any advice ?.
Many thanks
321
strip it down and clean see if the diaphragm is split or fit a new.
Thanks serco.
I have just done as you said but no difference, occationly it will stop
the diaphram have no splits. So i just dont know what!
Cheers
321
Hello
I think i have found the trouble: well this little arm float, where it hinges,
if you take the arm off and look at that end of the arn there is a small round rubber that is partly hollow one end, at the other of this rubber it's solid rubber, when i looked at it the solid part i found it was partly worn where it touches the diagrham. just like the solid washers on the brass/copper ones!
No where can i buy it Plymouth or Exeter only the whole thing £20+
Have you any idea where i could get one or how?.
It looks as if i will have to go the way serco suggest
as i say no where i can get parts of this thing.
many thanks
321
