DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Dual Flush Valve leaking
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
marky9074
from United Kingdom
PostPosted: Thu Jan 03, 2008 8:47 pm Reply with quote
Sorry more problems! Had a pre installed ideal standard dual flush valve in my cistern (its the type that overflows internally). I noticed that it had a constant flow of water once installed, so took it off and tightened the bottom back nut (thinking it was the external seal)
Once on again, it was still leaking. So I took it off, and had a look up with it full, and it was leaking internally, rather than through the external valve sealing washer.
All the overflow, float settings etc are ok. So is this a return or is there another seal I can look at? Seems like everything I have had from ideal standard has had a problem with it...
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Jan 03, 2008 9:07 pm Reply with quote
if you hold the valve half way down and twist it will come apart check if the rubber ring is seating fully.
Back to top
 Alert Moderators
marky9074
from United Kingdom
PostPosted: Thu Jan 03, 2008 9:14 pm Reply with quote
The whole top spins around so the buttons line up....
Its this one:
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Jan 03, 2008 9:18 pm Reply with quote
looking at your one the clip half way down by the overflow needs to be held in to release and the same on the other side
Back to top
 Alert Moderators
marky9074
from United Kingdom
PostPosted: Thu Jan 03, 2008 9:33 pm Reply with quote
OK, I see grey seal at bottom... looks ok, no imperfections icon_confused.gif
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Jan 03, 2008 9:36 pm Reply with quote
you should be able to get to seal. i don't reconise that valve. sometimes you get a bit of rough plastic etc from when it was made.
Back to top
 Alert Moderators
marky9074
from United Kingdom
PostPosted: Thu Jan 03, 2008 9:41 pm Reply with quote
http://www.geberit.co.uk/geberit/inet/uk/wcmsuk.nsf/pages/prod-san-flus-valv-1
I got it from Ideal Standard, but it is identical to this...
Back to top
 Alert Moderators
tincup
from United Kingdom
Thanked: 46 times
PostPosted: Thu Jan 03, 2008 9:44 pm Reply with quote
Hi
Gerberit (s**t spelling)
Check mating surfaces are flat and free of limescale or whatever.
Push the two lower lugs in and the body will come off. remove as much limescale from the guide rail in the middle.
If that fail down to buildbase buy another 24.99+vat
HTH
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Jan 03, 2008 9:48 pm Reply with quote
that cheap old rubbish from abroad that you get now days with new cisterns. i always change them for good english parts.
i can't see pic fully but you must be able to get to remove the rubber seal.
as on old ones they scale up after a few yrs and need cleaning.
Back to top
 Alert Moderators
marky9074
from United Kingdom
PostPosted: Thu Jan 03, 2008 10:04 pm Reply with quote
So what's a good English part then?
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Jan 03, 2008 10:08 pm Reply with quote
dudley are good and the parts are easy to get hold of
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Jan 03, 2008 10:10 pm Reply with quote
Back to top
 Alert Moderators
marky9074
from United Kingdom
PostPosted: Thu Jan 03, 2008 10:14 pm Reply with quote
cheers for that..
and you really change out all your OEM stuff with english gear? Are the valves that bad then or just deteriorate after time?
Mark
Back to top
 Alert Moderators
marky9074
from United Kingdom
PostPosted: Thu Jan 03, 2008 10:18 pm Reply with quote
I need a decent spanner for the lock nut as I am mangling this one with the stillsons.... not seen one of these in screwfix.. is this a special plumber tool icon_lol.gif
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Jan 03, 2008 10:30 pm Reply with quote
some are total cr*p and some just break after time and the spares are just not available.
i do mine hand tight then just nip up with a pair of pump
http://www.screwfix.com/prods/86411/Hand-Tools/Pliers-Cutters/Locking-Pliers/Irwin-Groovelock-12-300mm#
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
cistern leaking into pan Dual flush push button 9 600 Mon Jul 29, 2013 9:00 am
Fluidmaster Push Button Cable Dual Flush Valve instructions 2 280 Mon Jan 16, 2012 12:04 am
How do you fit a SIAMP Monaco dual flush valve? 2 3400 Fri Jun 12, 2009 6:42 pm
Fitting a Dudley Niagara Dual Flush Valve 11 8260 Sat Aug 11, 2007 8:42 am
Dual flush valve is banging 7 680 Fri May 08, 2009 7:47 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
