Spring balanced sash window dropping shut
30 Jan 2005
One of my spring balanced uPVC sash windows has a bottom sash that falls shut if it isn't propped up. Is there a way of adjusting the window so that the sash stays up?
Peter
the spring balance is probably broken. You can probably get a replacement if it is not obsolete.
Look up "Window Spring Balance" and compare the pictures with your own.
Probably it is one of a common brand in your area so a local supplier will be famiiar with it. This is a UK site and we have no knowledge of the Singapore market.
They are not at all expensive.
If you can tilt your windows inside the house for cleaning you should be able to replace the spring balance from the inside without the risk of the window falling out.
lay in a good stock of spring balances yourself.
they usually vary for length and weight.
Can you recommend any UK suppliers in case it makes sense for me to order them in myself?
Cheers,
PeterT
