DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Extending ADSL line from filtered socket?
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones
Author Message
wolfwiser
from United Kingdom
PostPosted: Mon Jan 07, 2008 4:28 pm Reply with quote
Hi, I wonder if anyone can help, I've searched round but can't really find an answer. My phone line enters the house upstairs to a (master) socket with a faceplate that has ports for both phone line and line to an ADSL modem.
I would like to extend this socket downstairs for use with a wired modem used for a games console. As my phones operate wirelessly from a base station at this master socket there is no problem there.
Can I simply add wires 2,3 and 5 to the master socket, send outside the house and in again where the new phone socket is required, and then use a microfilter and into the mode? I have read that if you do not do this correctly you can drastically reduce broadband speeds.
I realise that it would be preferable to extend a ethernet cable from a modem/router upstairs directy into the games cosole, but am not aware of amywhere you can 'make' your own ethernet cable to facillitate going through walls etc.
Any help very much appreciated, many thanks in advance.
Back to top
 Alert Moderators
JOHNBOY42
from United Kingdom
Thanked: 10 times
PostPosted: Mon Jan 07, 2008 5:39 pm Reply with quote
The faceplate has a built in filter so any connections off that will not need filtering,just run a extension wire and if its only for a game consul just use the 2-5 terminations.......but DO NOT add any more filters to the line,see www.adslnation.com this is full of useful info
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 238 times
PostPosted: Mon Jan 07, 2008 6:59 pm Reply with quote
You can buy cat5 cable by the 305M pull box from any serious computer supplier and in smaller lengths from the likes of B&Q and maplin. Plugs and wallports should also be availible from similar sources.
Plugs are put on with a special crimp tool basic ones of which can be had for about a tenner if you shop arround. Wallports are punched down in a similar way to phone points.
Note: cat5 cable comes in both solid and stranded core. If you use wallports you must use solid core. If you use plugs directly on the cable you must use the right plugs for the cable type (if plugs don't say which cable type they are for don't buy them).
Assuming the filter is a standard BT one no. The signal on the rear terminals of the BT filter is already filtered and you can't unfilter the signal.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones All times are GMT
Page 1 of 1
Jump to:
Wiring a filtered faceplate - no ADSL 2 100 Sun Dec 14, 2014 8:08 pm
Adsl filtered faceplate 8 1061 Wed Sep 19, 2007 12:58 am
NTE2000 ADSL Filtered Facelplate 6 1820 Sat Oct 03, 2009 6:03 pm
connections from filtered Faceplate to RJ11 Socket 27 1520 Thu Feb 10, 2011 4:09 pm
extending the bt master socket for a second router 21 440 Sat Sep 06, 2014 2:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
