DIYnot
Local | Network
   DIYnot > Forums
Local | Network
SLATE ROOF DRY VERGE?
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
merlin99
from United Kingdom
PostPosted: Wed Jan 09, 2008 11:07 pm Reply with quote
We have an old slate roof with slates set in cement at the verge. Is it possible to fit a dry verge or cap system? The house is right on the sea front so gets the full force of the weather.
Back to top
 Alert Moderators
safeway
from United Kingdom
PostPosted: Thu Jan 10, 2008 1:11 pm Reply with quote
Yes a Dry Verge can be fitted they are fitted by Secure mechanical fixing avoids wind uplift problems Completely weatherproof and maintenance free i am a member of www.trustedtradesmenltd.co.uk and do lots of jobs fitting dry verge systems. This is how to fit them.
To allow ventillation, underlay is left 30mm short of apex on each side. Before top tiling battens are fixed, a ridge tree batten is secured in position by a Ridge Batten Strap nailed to each rafter. If the Klober Uni-Dry Verge system is being used, the ridge batten must overhang the gable wall by 35mm to allow the Ridge End Cap to be fixed. If using a Block End Ridge, no overhang is required. Roof tiles are
laid in the normal manner. The Ridge Combs are placed over the ridge tree batten and nailed along the entire length of the ridge. Ridge tiles are positioned, connected by Ridge to Ridge Seals, then secured by hammering the special drive screw through the metal clamping plate and the Ridge to Ridge Seal into the ridge tree
batten. Ridge ends are finished with either a Uni-Dry Verge system, mortar or a block end ridge tile. Full fixing instructions are included in the Uni-Dry Ventilating Ridge pack.[/quote][/b][url][/url]
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 888 times
PostPosted: Thu Jan 10, 2008 2:07 pm Reply with quote
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Thu Jan 10, 2008 2:12 pm Reply with quote
as said above. the system is unlikely to work if the ridge tiles are the old staff'y blue type.
Back to top
 Alert Moderators
datarebal
from United Kingdom
Thanked: 103 times
PostPosted: Sun Jan 13, 2008 6:27 pm Reply with quote
verge?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Sun Jan 13, 2008 7:08 pm Reply with quote
datarebal wrote:
verge?
the dry verge system will only work with modern, pitched or segmental ridge, should the roof have a ridge that is. icon_wink.gif
i did not get the impression it was a lean-to roof.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Slate Roof Verge 5 920 Thu Jan 24, 2008 9:22 pm
Slate verge 5 240 Sun Apr 24, 2011 10:13 am
Verge on New loft roof cracked 14 460 Fri Jul 18, 2014 9:02 am
Roof tiles at Verge 2 140 Fri Feb 14, 2014 7:19 pm
Dry verge on half hipped roof 6 100 Wed Mar 14, 2012 7:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
