DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
3 loop, 1 switch?:
This topic originated from the How to page called Connecting a flex to a bulbholder
Click here to return to the page called Connecting a flex to a bulbholder.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
brakespear
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 05, 2004 10:06 am    Post Subject:
3 loop, 1 switch?:
Reply with quote Thanks
I am trying to fit a ceiling rose - unfortunately, the original light fitting had been removed before we moved in. I have a two gang switch controlling the hall and outside light (1 way fitting).
However, at the ceiling point I have three grey cables (one red, one black in each) and a white cable from switch (1 red, 1 black, 1 earth) - the ceiling batten I have only has sockets for 3 red and 3 black and I have four of each. Help!
UPDATE - just to muddy the waters, the white cable and one of the greys appears to run from the switch - however, there is no sleeve tape on any of the wires at the ceiling to show which is the switch cable.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Aug 05, 2004 12:31 pm    Post Subject:
you have cable without an earth?
if this is the case then your lighting cuircuit really should be rewired anyway
i would guess that the 3 grey cables are your normal cuircuit cables and switch cable and the white cable is a spur going to a juntion box from which another white switch cable and a cable to the light are run
Back to top
 Alert Moderators
brakespear
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 05, 2004 2:33 pm    Post Subject:
This being the case I need to make this safe until I can get this rewired - any ideas how I can wire this setuo to a standard light batten (ie switch, 3 live, earth and 3 neutral)?
If its any help - the 2 gang switch has the normal black back box with LI, L2 and Common at both ends. The grey cable black is L1 (bottom), the grey cable red is in Common (top). The white cable red is in L! (top) and the white cable black is in Common (bottom) There are two earths at the switch.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Aug 05, 2004 3:15 pm    Post Subject:
you need to find out which of the grey cables from the lighting point goes to the switch which means you need to test with a multimeter on its lowest resistance range (with power to the lighting cuircuit off ofc)
then connect as follows
all reds together in the central block of the pendant base
the black from the switch (which should technically be red sleeved) to the brown flex from the lampholder
the other 3 blacks to the blue flex from the lampholder
all earth wires to the earth terminal (generally one big bare metal terminal) in the lampholder
additionally if the outside light has any exposed metalwork run a peice of 4mm single earth from the lampholder earth terminal back to the earth block in the CU
this should make your lighting functional and reasonablly safe until you can get it rewired properly
Back to top
 Alert Moderators
brakespear
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 05, 2004 3:21 pm    Post Subject:
Thanks - I'll give it a go.
Back to top
 Alert Moderators
brakespear
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 05, 2004 4:52 pm    Post Subject:
Cheers - sussed out which is the switch cable.
I still have four red cables - one from switch, one from spur and two from loop - can I twist two of these together to fit three terminals, and, if so, which?
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Aug 05, 2004 4:55 pm    Post Subject:
don't twist just put them into the same terminal and screw it down
as long as they go to the right block it doesn't matter which two share a terminal
you will have the same thing with connecting the 3 blacks (NOT THE BLACK FROM THE SWITCH CABLE) with the blue flex from the light
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Thu Aug 05, 2004 4:59 pm    Post Subject:
you can always look in the reference section
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
brakespear
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 05, 2004 7:19 pm    Post Subject:
icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Thanks, plugwash - all appears to be working.
You're a star!
Breezer:
Sorry - I had a diagram for a standard connection, just wasn't sure what to do with the extra cable. Must have missed it in the reference section icon_redface.gif
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Aug 05, 2004 7:50 pm    Post Subject:
there are no specific diagrams for it but its a logical extention that most people with a clue about electrics would figure out pretty quick icon_wink.gif
locked to prevent hi jacking
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
Dimmer switch wiring on end of loop 15 460 Wed Aug 12, 2009 2:12 pm
loop at the switch 5 420 Fri Oct 20, 2006 1:49 pm
loop in at the switch 75 1580 Sun May 25, 2008 2:05 pm
loop impedence on a tt system 10 640 Tue Oct 02, 2007 5:09 pm
ABNORMAL EARTH LOOP TEST AT BOILER 6 360 Wed Sep 26, 2007 4:39 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
