PUTTING IN TRICKLE VENTS TO 4 STOREY FLAT
13 Feb 2006
Tyne and Wear
IS IT POSSIBLE TO PUT TRICKLE VENTS INTO A UPVC WINDOW FROM THE INSIDE ONLY.
THE FLAT IS ON THE TOP FLOOR OF A 4 STOREY BLOCK AND ACCESS WOULD GREATLY ADD TO THE COST.
try removing sash bring inside, fit vent safely, then reverse procedure. but please do not drop sash its a long way down :oops:
a little more difficult if friction hinges are riveted
I've done this recently, not 4 storey i admit but i did the upstairs windows (which were rivited) with no problem at all.
Only had to take the glass out of the 1st one, to have a look at the construction and then just drilled and grinded away.
Matt
