DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Water Hammer
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
canwefixit
from United Kingdom
PostPosted: Wed Jan 16, 2008 10:10 pm Reply with quote
Anyone had any experience of the "Mini Rester" on the Toolstation website (code 85345 )which is meant to stop water hammer? If so did it work and where did you fit it??
We've got hammer which we think is caused by a toilet which was not converted from low to high pressure when the plumbing was changed to a pressurised sytem. Unfortunately the loo in question is one that encloses all the pipework and has then been sealed all round to the the tiles so getting out to change the inards of the cistern could be a major job!!
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Wed Jan 16, 2008 10:49 pm Reply with quote
Find the pipe that is leading to the enclosed space and put a flow restrictor on it.
Back to top
 Alert Moderators
canwefixit
from United Kingdom
PostPosted: Thu Jan 17, 2008 6:49 pm Reply with quote
Unfortunately the feed for the loo is off of a 22mm pipe under a tiled floor that also supplies a wash basin and a shower so a flow reducer would have to be fitted to the 22mm pipe and would affect all three.
Back to top
 Alert Moderators
JPC
from United Kingdom
Thanked: 20 times
PostPosted: Thu Jan 17, 2008 6:54 pm Reply with quote
was the cold water to toilet actually changed from tank to mains ?
Back to top
 Alert Moderators
canwefixit
from United Kingdom
PostPosted: Thu Jan 17, 2008 9:08 pm Reply with quote
James, yes.....no cold tank, system now has a Mega-flo so everthing at mains pressure.
Noise normally occurs when loo is flushed ,but can be reduced by turning on the wash basin cold tap while loo is re-filling.
Back to top
 Alert Moderators
welsford46
from United Kingdom
PostPosted: Sat Jan 19, 2008 3:10 pm Reply with quote
Yes i've used one successfully to get rid of water hammering caused by a dishwasher
Back to top
 Alert Moderators
Bamber gaspipe
from United States of America
PostPosted: Sat Jan 19, 2008 3:16 pm Reply with quote
Mega flow won`t make any difference to your toilet, most toilets are mains fed anyway, unless it`s an antique, probably poor pipe support.
Back to top
 Alert Moderators
canwefixit
from United Kingdom
PostPosted: Sun Jan 20, 2008 12:14 am Reply with quote
welsford46 out of interest where abouts did you fit the device, was it close to the dishwasher?
bamber gp I think after further investigation you may be right, it seems that it doesn't matter which tap is turned on to lessen the noise (can be hot or cold) and I assume that the noise is caused when the loo is flushed because a valve is going from closed to fully open very quickly.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Water hammer since removing old lead ... 6 340 Thu May 07, 2009 1:04 pm
Hearing next door's water hammer? 3 400 Tue Jul 14, 2009 8:13 am
Water Hammer? 4 60 Sat May 18, 2013 11:05 am
Clanging heating- water hammer? HEEELP!! 3 100 Mon Dec 24, 2012 6:52 pm
Water Hammer Problems 2 120 Tue Oct 05, 2010 8:58 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
