The New Micro Type Bayonet Cooker Hose !!!
25 Mar 2006
Essex
Could someone tell me if the new smaller type (named micro I think) bayonet cooker hose is suitable for a free standing cooker or designed for use with hob or similar with limited or lesser demand.
Many thanks
The new micropoint??? been out since about 1982 if not earlier yes perfectly ok for a standard cooker
The new micropoint??? been out since about 1981 if not earlier yes perfectly ok for a standard cooker
Thanks for that, I had just only fitted it and just now had a horrible thought that it may only be suitable (size of bore) for a hob!
Cooker hoses and hobs Do Not go together well.
the oven underneath tends to damage the rubber and cause GAS LEAKS.
Good advice, yes there is not much room in that situation, would you use something like 10mm soft copper?
