DIYnot
Local | Network
   DIYnot > Forums
Local | Network
halsted ace boiler- power light flashing and no hot water or
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
rcy
from United Kingdom
PostPosted: Mon Jan 21, 2008 8:36 pm Reply with quote
hi,
having a problem with my halsted- was ok this am- came home and was not on as per the timer- went to see and the power light LED green is flashing regularaly- looked also at pressure bar - zero- have no idea what to do...can anyone help??
Back to top
 Alert Moderators
rcy
from United Kingdom
PostPosted: Mon Jan 21, 2008 8:42 pm Reply with quote
PLEASE CAN ANYONE HELP???
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 297 times
PostPosted: Mon Jan 21, 2008 8:45 pm Reply with quote
Pressurise system upto 1bar.
Reset boiler.
you may need to reset limit stat! (It lives under bottom panel at l/h side!
Back to top
 Alert Moderators
Rob
from United Kingdom
Thanked: 380 times
PostPosted: Mon Jan 21, 2008 8:47 pm Reply with quote
look here. item 6.
When its refilled just hold the reset for 5 seconds
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Mon Jan 21, 2008 9:03 pm Reply with quote
Once the boiler is going, it might be an idea to monitor the pressure and if it keeps falling, find out where the water goes.
Back to top
 Alert Moderators
rcy
from United Kingdom
PostPosted: Mon Jan 21, 2008 9:29 pm Reply with quote
THANKS ....will try my best and see if it works....
Back to top
 Alert Moderators
rcy
from United Kingdom
PostPosted: Mon Jan 21, 2008 11:05 pm Reply with quote
me again
look i know i'm going to sound really dumb (but i am not blonde!...altho i am only a gal)...when filling a sealed system...as indicated in ITEM 6...to fill it...do i turn ON the valve near the MAINS WATER AND THE 2ND VALVE AT THE OTHER END OF THE FLEXIBLE CONNNECTION AT THE SAME TIME....then when the press is just over 1 bar then switch both off...i presume what i am doing is letting in some water from the mains to the return heating pipes and hence to the boiler????
Back to top
 Alert Moderators
rcy
from United Kingdom
PostPosted: Mon Jan 21, 2008 11:08 pm Reply with quote
rob884 wrote:
look here. item 6.
look i know i'm going to sound really dumb (but i am not blonde!...altho i am only a gal)...when filling a sealed system...as indicated in ITEM 6...to fill it...do i turn ON the valve near the MAINS WATER AND THE 2ND VALVE AT THE OTHER END OF THE FLEXIBLE CONNNECTION AT THE SAME TIME....then when the press is just over 1 bar then switch both off...i presume what i am doing is letting in some water from the mains to the return heating pipes and hence to the boiler????...and this RESET thing... icon_confused.gif
Back to top
 Alert Moderators
Trundles Tricks
from United Kingdom
PostPosted: Tue Jan 22, 2008 12:19 am Reply with quote
Yes
You can turn the valves on one at a time if there are two, you will hear the water going into the system, take it easy and then just turn the valves off one at a time (just the one initially will stop the water you will hear it stop)
Pressurise up to about 1 and a quarter bar, don't worry if you exceed this slightly as long as you don't start getting past 2 bar.
When doing this in the future always check guage reading when system is cold, and don't forget that when system warms up the pressure will increase because warm water expands.
A safety valve will blow off outside (hopefully if pipe connected) if the pressure approaches or exceeds 3 bar.
If your boiler overheated due to being empty before shutting down the safety switch may have triggered, If you look underneath the boiler at the front left hand side you will see a small round reddish switch press it in, if its popped out you will feel a definite click, if it hasn't you will feel a solid resistance straight away.
Turn boiler control switch all the way to reset and let go, it will spring back and Bob's your uncle (unless you have fatally damaged your boiler by letting it run dry) in which case call out one of the boiler surgeons on here to repair.
Back to top
 Alert Moderators
rcy
from United Kingdom
PostPosted: Tue Jan 22, 2008 12:49 am Reply with quote
THANK YOU xxx
Back to top
 Alert Moderators
mattsparky1
from United Kingdom
PostPosted: Tue Sep 13, 2011 8:30 pm Reply with quote
i have just encounted this problem checked flow switch, flame probe etc
lastly i checked pump this had stopped rotating and is the route of my problem hope this may help someone in the future
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3436 times
PostPosted: Wed Sep 14, 2011 12:09 am Reply with quote
Matt, your fault has no relevance at all to what the OP has described.
Furthermore, for your first post you have chosen to add to a thread which is three years old!
Back to top
 Alert Moderators
mattsparky1
from United Kingdom
PostPosted: Sat Sep 17, 2011 8:01 pm Reply with quote
apologizes Agile, when i originally posted a search ( before becoming a member)for flash green power light on halstead boiler this link came at the top. Someone else may have the same problem as myself and could save them some hassle even though the link is old its not out of date its hard work trying to be helpful. No wonder i never join chat rooms!!!!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Halsted Quattro Boiler Fault 8 80 Tue Oct 07, 2014 11:31 am
halsted boiler 2 80 Mon Feb 07, 2011 1:11 pm
wet halsted boiler 2 241 Fri Jan 08, 2010 9:38 pm
Halsted finest gold 4 1320 Fri Nov 17, 2006 5:25 pm
Halsted finest platinum banging 4 380 Mon Sep 03, 2007 12:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
