bengasman
Joined: 28 Jan 2005 Posts: 26969 Location: London, United Kingdom Thanked: 2164 times
Posted: Tue Jan 22, 2008 12:41 pm |
Cylinder lock with key snapped off inside it, at least 2mm inside, no chance of gripping it.
Tried hitting the lock to move the stub enough to grip it; not a chance.
I can only see 2 screws on the side of the lock, but lock won’t budge when I undo these. Most locks I have seen have at least 3 screws, where is the last one likely to be hidden? There is a cover around the lock on the outside, what is the likelihood that it is under there? As it is accessible from the outside I have not undone it yet as the screws that hold this in place are hard to get to and painted over so many times that the thread is hardly visible.
No brand name on the lock, looks rather old and cheap.
Would have happily broken the old piece of junk out and replaced with good quality new one but practical reasons make this the last option unfortunately. |
big-all
Joined: 12 Jul 2004 Posts: 12074 Location: Surrey, United Kingdom Thanked: 649 times
Posted: Tue Jan 22, 2008 1:17 pm |
if you undo the screws on the edge of the door the lock should slide towards the edge releasing from the luggs on the back plate!!
perhaps its painted into position and needs a [sidways]tap to loosten it!! |
MasterAbacus
Joined: 16 Jun 2005 Posts: 542 Location: Yorkshire, United Kingdom
Posted: Tue Jan 22, 2008 2:27 pm |
Have you tried using a Magnet to help get it out?
Or a paper clip with a very small amount of super glue on it...
Could try a spare key from the opposte side too.... or something longer and thinner to push it back... |
JohnD
Joined: 15 Nov 2005 Posts: 34352 Location: Hampshire, United Kingdom Thanked: 1087 times
Posted: Tue Jan 22, 2008 3:02 pm |
do you mean it's a yale-type nightlatch?
If it has two screws into the door edge and none on the body of the lock facing into the room, then it will be slid onto a metal plate underneath, which is itself screwed to the inside face of the door. In this case, undo the two edge screws, and tap the latch body towards the edge of the door, this will free it from the retaining lugs. Once the body is off, you can undo the screws holding the cylinder to the backing plate, pull the cylinder off to the outside, and you will see a slit in the plug of the cylinder that you can poke with a thin wire. Or buy a new cylinder for negligible cost.
If that's not right, post a pic. |
bengasman
Posted: Tue Jan 22, 2008 8:45 pm |
Took the screws out again and gave it a gentle tap. Nothing
A firm tap nothing. Nothing.
But a good whack did the job. Cheers mate. |
