DIYnot
Local | Network
   DIYnot > Forums
Local | Network
gravity fed water system problem
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
bash1978
from United Kingdom
PostPosted: Wed Jan 23, 2008 3:41 pm Reply with quote
I hope someone can give me some advice on the following:
I have recently moved into a new home and have an ldeal classic boiler which pumps water for heating and has a gravity fed water system used to warm the water. The tank I have is a primatic tank and have a header tank in the loft.
The problem is this, if I switch on both my heating and water at the same time, I find I create some sort of air lock in the system so my water doesn't heat up as it should, the Gravity Flow pipe from the boiler is usually cold and the Gravity Return pipe is boiling hot. The heating works a treat no problems.
The only way of resolving this I have found is to drain the system from the cylinder and refill and all is well and it stays well aslong as I heat up the water for 5-10 mins before I switch on my heating. So I can't utlise the timer during these very cold morning to heat up the house!
I have checked the piping as much as I can (its diffcult to follow it to the tank) and there doesn't seem to be any sort of valve to help remove an airlock.
Any advice will be much appriaciated.
Back to top
 Alert Moderators
lopez11
from United Kingdom
PostPosted: Wed Jan 23, 2008 4:03 pm Reply with quote
Rip out the primatic, have it converted to a fully pumped system and have it sealed as well icon_biggrin.gif
Back to top
 Alert Moderators
bash1978
from United Kingdom
PostPosted: Wed Jan 23, 2008 4:09 pm Reply with quote
thanks lopez, I will be replacing the bulk of the system in a few years to a combi system, but was hoping to get a "quick fix" to this issue, any other suggestions ?
Back to top
 Alert Moderators
izzy eckerslike
from United Kingdom
PostPosted: Wed Jan 23, 2008 4:55 pm Reply with quote
It seems I have more or less the same problem as you Bash, altho I don't think my cylinder is primatic
see my thread http://www.diynot.com/forums/viewtopic.php?t=120935
Back to top
 Alert Moderators
bash1978
from United Kingdom
PostPosted: Wed Jan 23, 2008 5:07 pm Reply with quote
hi izzy,
seems similar, but I think the solutions are probably very different. My boiler has 4 pipes coming out, 2 for water, Flow and Return and 2 for heating pumped flow and return. So heating is fine as its pumped, but the gravity fed bit is problematic. I am trying to understand why the water flow seems to be going back i.e.e return pipe gets hot and flow pipe doesn't ?
Back to top
 Alert Moderators
izzy eckerslike
from United Kingdom
PostPosted: Wed Jan 23, 2008 5:21 pm Reply with quote
My boiler has the same four pipes, the hot water pair are a bigger bore than the heating pair tho
Back to top
 Alert Moderators
bash1978
from United Kingdom
PostPosted: Wed Jan 23, 2008 5:33 pm Reply with quote
I see, just re-read your thread, I think maybe what you should try is whats called "cracking" the nuts open a little on the coil inlet pipe at the top and the outpipe at the bottom of the cylinder. If there is any air it will soon be noticable. Other than that i'd re-try emptying the heating system and re-filling.
Back to top
 Alert Moderators
izzy eckerslike
from United Kingdom
PostPosted: Wed Jan 23, 2008 5:47 pm Reply with quote
I don't think I have a primatic cylinder, we do have two tanks, the pipework looks very old 1960's possibly so I am wary of loosening the nuts as they look gunged up somewhat, I just took off the lagging to see if there is any way to bleed the coil but no luck there.
My boiler is a Myson Marathon incidently
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
DHW problem on Pumped CH Gravity DHW system 4 300 Mon Dec 07, 2009 3:38 pm
Bit of a problem - draining gravity system 9 700 Sun May 06, 2007 7:13 am
Gravity Heating System Replacement Problem 7 120 Fri Aug 26, 2011 11:23 am
still problem with gravity feed system 4 120 Fri Jan 28, 2011 7:44 pm
My dhw gravity fed pumped heating system problem. 2 940 Thu Nov 05, 2009 2:03 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
