Sealing round the edge of a wooden worktop
21 Sep 2007
Sussex
What do people recommend?
The worktops are oiled oak, and I'm fitting a glass splashback. I was going to leave about 4mm gap between the top surface of the wood and the bottom of the glass, and fill it with low-modulus silicone, so that the wood can move.
Will the silicone stick to the oiled wood OK? I was planning on wiping down the edge with white spirit first to remove surface oil, but is that enough?
I can't recommend a sealant, but don't use white spirit to prep for any sealant as it is oil based, use meths.
You might have geussed I wouldn't use silicone. Acrylic would be better, or a polyurethane like Sikaflex would be better.
Meths it is then.
Oilman, what's the problem with silicone? I used acrylic round a bath once and I'm never doing that again! I'll definitely stick to silicone in the bathroom.
hi Hoo
Can I ask? How are you fixing the glass splashback to the walls?
I too have a gap around the wooden worktop that needs sealing in some fashion. If I find any other advice I will let you know.
many thanks
Silicone migrates everywhere, and penetrates the surface of wood. Once it's in it's not coming out, but it makes a good release agent when you want to get something else on the surface.
Hi oilman
what type of Sikaflex would you recommend using - and would this be ok for sealing the gap between wood and metal splashback as well? Or wood and plaster painted wall?
many thanks!
Hooo - yuk idea to apply a bead of sealant to the front of the glass/worktop interface - neatly applying sealant is an 'artform' that few master so often the end result looks naff. The correct way of sealing upstands is to apply the sealant to the worktop/wall interface then drop the upstand down onto it thus sealing under the upstand; wipe clear any excess (there probably won't be any if done properly - don't use too much). The end result is a clean, sharp corner where the upstand touches the w/top, sealed below & behind. Use transparent sealant.
Oilman
Ah OK. I've never used silicone on wood, it's a good thing I asked. I'll look out for Sikaflex instead. Is it reasonably easy to find, or is it a specialist item?
I did a bit of a Google, most results are boat related. There's also quite a range of grades. What grade do you use, and can you point me at a supplier?
damson
I'm planning to use mirror adhesive to fix the splashbacks, as recommended by the glazier who supplied the glass.
Symptoms
I can see that's a much neater way of doing it, but I'm concerned about having the glass directly onto the wood. Wooden worktops are mounted in slotted brackets with a gap to the wall, so that the wood can expand and contract. If the glass is stuck directly to the wood and the wall, I'm worried about it cracking as the wood moves.
oilman
How about the windowsill on your boat, does that get wet? :D
Looking up Sikaflex on t'internet there appear to be a number of Sikaflex products. Which one would you recommend?
