The knack of Setting out brickwork square to house
1 May 2005
Lancashire
Will a qualified brickie please advise the rules (cos without rules where would we be)
l am tired of arguing the toss with "conservatory base builders" who are constantly erecting out of true dwarf walls.
On a regular 3 waller I have advised ignoring the bendy house walls and setting the corners square (with a square) as well as measuring for parallel and diagonals, to make sure our frames fit.
But the "racketheye" guys seem to build the corners out of square so the new runs from the bendy house walls look square.
Sorry, please read that gibberish a few times before you guide me in the right direction.
i guess a connie base needs to be square regardless of the house wall.
if we are adding an extension, and one elevation of the extension is parallel to the house and the other two follow the existing house walls in-line, then we usually have to follow the existing line.
even if the house is slightly diamond shaped. it would look dog-legged if we tried to square it up true.
if needs be, you can help to square the blockwork internally but only by a few mill.
if the job demanded, and the customer insisted, we do try and halve the difference. though most customers would choose what looks best.
I can't see how a house wall is going to be very far out in the 3-4m width of a conservatory, so it should be be no problem to form a parallel line off the existing elevation wall and then squaring back off this or squaring out off the building.
If there is an adjacent end elevation, then they can pull a line out off this too and then square off that.
Is also important to check the diagonals for squareness, and then jig the lines a bit if necessary
It's really basic stuff and if the guys can't handle it, then perhaps they should be relegated to manholes and get a new gang in?
Or can't you make the cill section and give them that to set out to?
I shudder to think how they will cope with a octagonal base, and I can just picture all those massive perp joints, and badly set out/gauged/leveled brickwork and compo all over the bricks and patio :eek:
