DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Memera fuse problem
Author Message
Caspian Rho
from United Kingdom
PostPosted: Mon Jan 28, 2008 11:03 pm Reply with quote
Just need some info on changing a fuse in a Memera 2000 (AP4) box?
We had a toaster malfunction earlier this evening, even though it didn't trip any other switches on the box or the box itself. Our shower now seems to have stopped working with no power going to it whatsoever (Redring expressions 500).
We've had no faults with the shower until tonight. So I can only surmise the toaster burning out somehow effected the shower fuse (but no other fuses in the box show any signs of being effected?)
I'm not a qualified electrician. Other than changing a few plugs and the odd 'fat' fuse. Electric boxes are something I won't tamper with too much.
If someone can instruct me briefly how to get the fuse out, that would be brilliant. Any help is greatly appreciated, Thanks for your time.
Back to top
 Alert Moderators
333rocky333
from United Kingdom
Thanked: 297 times
PostPosted: Mon Jan 28, 2008 11:11 pm Reply with quote
Memera 2000
Thought they were mcb's not fuses
Back to top
 Alert Moderators
Caspian Rho
from United Kingdom
PostPosted: Mon Jan 28, 2008 11:16 pm Reply with quote
lol probably the reason I can't see where to change the fuse!
How do the MCB's work?? Do they need changing like a fuse if there is an appliance problem?
Back to top
 Alert Moderators
333rocky333
from United Kingdom
Thanked: 297 times
PostPosted: Mon Jan 28, 2008 11:34 pm Reply with quote
they should all be sort of in line
ie all normally pointing the same way
Cant remember mem
But is upwards on most mcb types
If you get what I mean
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 457 times
PostPosted: Tue Jan 29, 2008 12:07 am Reply with quote
The OP probably has BS1361 fuse carriers in his MEM 2K board.
See here:
http://www.electrika.com/products/m/man-0260/pdftech/2005-protective-dev.pdf
Back to top
 Alert Moderators
333rocky333
from United Kingdom
Thanked: 297 times
PostPosted: Tue Jan 29, 2008 12:20 am Reply with quote
Are they the black ones with two coloured dots on
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 457 times
PostPosted: Tue Jan 29, 2008 12:41 am Reply with quote
Nope. Thats Memera 21.
See the PDF. There are HRC fuse carriers for the Memera 2000 range.
The OP mentions "fat fuses". They sound like 1361's to me...
Back to top
 Alert Moderators
333rocky333
from United Kingdom
Thanked: 297 times
PostPosted: Tue Jan 29, 2008 12:54 am Reply with quote
Found em
Ac10
never ever seen them before
Back to top
 Alert Moderators
Caspian Rho
from United Kingdom
PostPosted: Tue Jan 29, 2008 12:59 am Reply with quote
the 'fat' fuses I mentioned was in reference to the most experience I've had with fuse boxes lol (they're our central heating ones on the memea 3 box!)
the 2000 box has the little grey pluggy things AD32B is the shower plug one. But like I said none of the other electrics on the 2000 were effected, just the shower one (so I don't know if it is the box or shower!)
I'm not sure how to change the grey pluggy boxes or if indeed that's the problem.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 146 times
PostPosted: Tue Jan 29, 2008 9:15 am Reply with quote
AD32B is a 32A B curve BSEN60898 circuit breaker, it doesn't have to be replaced after each use like a fuse does, it has a lever on the front, down is off and up is on, just make sure its properly in the off position and then push it back up to the top and the power should come back on icon_smile.gif
Back to top
 Alert Moderators
Caspian Rho
from United Kingdom
PostPosted: Tue Jan 29, 2008 10:58 am Reply with quote
Thanks for the replies lads. All switches are up, turned off and then up just to make sure they click to on.
There still seems to be no power going to the shower. It has a cord to pull off and on, would I be right in saying this can burn out or maybe it contains some sort of fuse?? The shower is a Redring Expressions 500?
cheers
Back to top
 Alert Moderators
Caspian Rho
from United Kingdom
PostPosted: Wed Jan 30, 2008 2:35 am Reply with quote
Does anyone have any other suggestions?
Back to top
 Alert Moderators
kkynaston
from United Kingdom
PostPosted: Wed Jan 30, 2008 7:16 am Reply with quote
Can you post a picture of your consumer unit/fuseboard?
Does you shower pull switch have a neon light on it?
If so does it illuminate when the pull the chord?
If not and you say they all your MCB's are on, then you may have a loose connection. You would need to isolate the supply and check all connections.
Back to top
 Alert Moderators
Caspian Rho
from United Kingdom
PostPosted: Thu Jan 31, 2008 1:21 pm Reply with quote
hi thanks for the reply. Ended up calling a 'sparks' anyway. which was always the intention lol
Just wanted to know what I was dealing with beforehand. That old adage 'seen you coming' was what I was trying to avoid.
Thanks kkynaston, seems your diagnosis was spot on. Loose connection in the cord switch itself which burned out the switch.
Again thanks for all the help!
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
MEM MEMERA CART. FUSE - Drop in Replacement Circuit Breaker? 8 540 Sun Aug 08, 2010 8:38 am
Shower / Memera 2000 fuse box trip 8 900 Thu Jun 03, 2010 6:19 pm
memera 3 5a fuse 9 180 Wed Oct 09, 2013 7:44 pm
memera fuse box 2 500 Fri Apr 11, 2008 8:02 pm
memera 2000 fuse box 19 8620 Thu Sep 22, 2005 7:20 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
