DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Water leaking from electric shower unit
Author Message
cream69
from United Kingdom
PostPosted: Tue Jan 29, 2008 1:00 pm Reply with quote
Hi there! Had the shower installed about 5 years ago,no problems,
then yesterday water started leaking from the bottom of the actual unit itself. I've isolate the electricity supply to the shower just to be on the safe side.It's a Triton Bezique 10.5kw.
Any help would be much appreciated.
Back to top
 Alert Moderators
kkynaston
from United Kingdom
PostPosted: Tue Jan 29, 2008 3:53 pm Reply with quote
Could be a pressure relief valve due to blockages in the works, although pressure relief normally only 'relieves' when the shower is running.
I would put it down to a loose pipe supplying the shower
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Tue Jan 29, 2008 4:51 pm Reply with quote
Remove the cover.
Turn the shower on.
Observe where water comes from.
Repair.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 720 times
PostPosted: Tue Jan 29, 2008 5:00 pm Reply with quote
BAS, you always make it sound so easy !
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Tue Jan 29, 2008 5:03 pm Reply with quote
Is it not?
Back to top
 Alert Moderators
newboy
from United Kingdom
Thanked: 9 times
PostPosted: Tue Jan 29, 2008 8:56 pm Reply with quote
If the water is coming out of a small stub of plastic pipe next to the shower hose then the PRV has been triggered. On the smaller triton units the PRV is not resealable and needs to be replaced - it's a ball bearing in a seat and when the pressure goes over limit the ball is forced through the tube and disappears down the drain! Replacment of the valve is needed - but you need to check why it operated.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 187 times
PostPosted: Tue Jan 29, 2008 8:57 pm Reply with quote
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Tue Jan 29, 2008 9:16 pm Reply with quote
I've had a PRV operate.
No way would I describe the result as water "leaking" from the bottom of the shower....
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 8 times
PostPosted: Tue Jan 29, 2008 9:36 pm Reply with quote
A five year-old Triton, in London, is likely to be full of scale, which leads to the PRD (it isn't a valve) opening.
Unless it isn't coming from the PRD tube then you won't need to take the cover off to investigate.
If you do remove the cover, then isolate at the DP switch first.
If you find a leak coming from a push-fit connector on the inlet, then it's been installed incorrectly.
If the PRD has opened owing to a scaled can, then you need a new PRD (part number 83301330i) and a new heater can (part number 84500670i).
Tip: if you replace the can, take the old O ring off the inlet and be prepared to put it on the new one, because Triton seem to be in the habit of supplying an O ring that fits the 'Topaz' range, and it doesn't seal very well on the older units.
Use silicone grease on the O rings when you reassemble.
Back to top
 Alert Moderators
cream69
from United Kingdom
PostPosted: Wed Jan 30, 2008 11:45 am Reply with quote
Hi!, thanks for the prompt replys. I opened
the unit this morning turned the shower on
and then quickly off and the water seems to
be seeping from the stabilizer valve assembly fig.11.
Theres water dropslets on top edge of the valve assembly dripping down.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Wed Jan 30, 2008 12:24 pm Reply with quote
I guess you need a new one of those then, unless there's a replaceable gasket on the top. Probably unlikely.
showerdoctor is another good online supplier of parts.
Back to top
 Alert Moderators
cream69
from United Kingdom
PostPosted: Wed Jan 30, 2008 12:32 pm Reply with quote
Here's an actual pic.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1337 times
PostPosted: Wed Jan 30, 2008 1:11 pm Reply with quote
I'm just wondering - London, hard water, 5-year old shower...
Could that wossname be leaking because the heater can is furred up, and offering too much resistance, so the pressure is too high?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 8 times
PostPosted: Wed Jan 30, 2008 3:14 pm Reply with quote
I can't see from the picture where the water is coming from, but a new stabiliser is cheap, so I would just get one and fit it.
___________________
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Oil Leaking From Service Head 9 700 Thu Apr 17, 2008 5:05 pm
Oil Leaking From Service Head 10 1380 Sun Feb 04, 2007 12:19 pm
Leaking Pressure Relief Pipe 2 2362 Sat Jan 06, 2007 3:46 pm
Please help! Electricity conduit leaking through wall? 2 922 Thu Aug 25, 2005 11:35 pm
Triton Jade - Leaking now stopped 5 640 Sun Aug 23, 2009 7:57 am
DIYnot
