What protection is required for a soil pipe in concrete?
30 Jan 2008
Humberside
I am putting a concrete floor into a stable coversion. The soil pipe is buried in pea gravel but what should I do to it as it passes through the concrete to prevent damage to the soil pipe if any movement takes place.
Many thanks.
how much coverage will there be between the underside of the concrete floor and the top of the pipe?
are you referring to the position of the pipe where it penetrates the floor?
Yes I am only interested in what protection, if any, I should put around the pipe as it penetrates the concrete floor.
I note from document H of teh building regs that when horizontal pipes re cast in concrete the only protection required is compresible material at joints - however there wo't be any joints as the pipe will pass perpedicularly through the concrete floor.
unless you think the floor may be vulnerable to clay heave, then you will not need any form of flexibility allowance at this point.
There you go ;)
