DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How can I fix a toilet to tiles without drilling?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
mark306
from United Kingdom
PostPosted: Wed Jan 30, 2008 7:55 pm Reply with quote
I've recently tiled our bathroom floor and have fitted the toilet. I don't want to drill into the tiles (lots of pipes below) I was thinking of using no more nails to attach the toilet to the floor. Has anyone got any thoughts on this or alternatives?
Mark
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 770 times
PostPosted: Wed Jan 30, 2008 8:24 pm Reply with quote
Silicone has been widely used on new build, but don't touch the pan for 24 hrs after fixing it.
I don't personally agree with this and it should be drilled and fixed.
Back to top
 Alert Moderators
mark306
from United Kingdom
PostPosted: Wed Jan 30, 2008 9:20 pm Reply with quote
Has anyone tried concreting a toilet to tiles? Maybe this is a another opition... Thanks for your feedback
Back to top
 Alert Moderators
fitz1
from United Kingdom
Thanked: 20 times
PostPosted: Wed Jan 30, 2008 9:23 pm Reply with quote
generally there aint enough key on the tiles for the cement to adhere to.mark and dill the pan and silicone the cistern if its a close coupled.
Back to top
 Alert Moderators
macgee
from United Kingdom
PostPosted: Wed Jan 30, 2008 9:24 pm Reply with quote
Whats the floor under the tiles? ( floor boards, solid floor?) If floor boards, did you put ply board down on top before tiling? icon_biggrin.gif
Back to top
 Alert Moderators
bigbeak07
from United Kingdom
Thanked: 3 times
floor tile adhesive, or silicone as mentioned before.It will need time to set tho! doesn't beat screw's and plugs tho!
Back to top
 Alert Moderators
mark306
from United Kingdom
PostPosted: Wed Jan 30, 2008 9:47 pm Reply with quote
18 inch WPB ply - yes i didn't make that mistake
Back to top
 Alert Moderators
macgee
from United Kingdom
PostPosted: Wed Jan 30, 2008 9:57 pm Reply with quote
Wasnt trying to catch you out, my point is, if you have 18mm ply plus thickness of your tile and adhesive ( 9-10mm thick, guess) it means that if you drill through the tile, then use 40-50mm wood screws ( extra length to allow for toilet), plus a little silicone as the others have mentioned. Then it isn't an issue where the pipes are and the toilets not going anywhere.
Back to top
 Alert Moderators
mark306
from United Kingdom
PostPosted: Wed Jan 30, 2008 10:41 pm Reply with quote
good idea macgee, will give that a go...
Back to top
 Alert Moderators
tonybhoy
from United Kingdom
Thanked: 1053 times
PostPosted: Wed Jan 30, 2008 11:44 pm Reply with quote
Cement could crack the WC bowl depending on the mix.
Only way is to use screws.Silcone and the other stuff won't work.
Over time the bowl will become loose.
Back to top
 Alert Moderators
Kes
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jan 31, 2008 10:28 am Reply with quote
A strong compo mix (sand and cement) was the accepted method of (permanently) fixing a toilet bowl to any hard surface. Don't see it much anymore
I fitted a bowl in our downstairs loo about three years ago onto tiles with Sitcks Like Sh*te, available from plumbers merchants. I spoke to the tech dept and they agreed that it would be fine, as it has been up to now. As with compo, don't sit on the thing for a day or two.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
drilling tiles for bar shower fixing kit 7 180 Sun Dec 14, 2014 9:00 pm
Drilling a hole through fitted tiles. 8 140 Mon Oct 10, 2011 12:32 pm
Gluing toilet pan to tiles? 26 2220 Thu Dec 30, 2010 12:01 am
between toilet and tiles...? 2 220 Sun Sep 26, 2010 1:05 am
Should I tile around the toilet pan on sit the pan on tiles? 16 1660 Tue Sep 08, 2009 10:33 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
