Spy hole on plastic door
3 Feb 2008
Hertfordshire
This is my first post on what looks like a great forum.
I am hoping somebody can help me.
I have a solid plastic front door (about 64mm thick) and i need a to fit a spy hole but all of the spy holes i have found are for doors upto 60mm.
Ian
The Chubb WS9 Door Viewer fits doors 40mm-95mm thick, but it is a staggering £46 from most places :eek:
Huge thanks for your reply woody. I just need to find one a bit cheaper. At least i know they do make one.
Does anyone else know of a spy hole apart from The Chubb WS9 that will do the same thickness. I don't want to be spending nearly £50 on a spy hole.
Please please please!!!!!!
Someone must know of a spyhole with a longer length than 64mm.
I really don't want to be spending £46 on one though.
Hi IanPlumber,
If I were you look at a company called www.fabnfix.co.uk if you give them a call they will be able to point you in the direction of a distributor of their products. They supply a lot of door manufacturers with their products so should be able to help.
Hope its a result for you!
