I have a prima 40f boiler . I recently changed the PCB when it would not start up . Now when it starts the main burner runs for about 12 seconds , and stops , it then restarts after about 8 seconds ,and operates in this manner continuously .The hot water and heating are OK . Viewing the main burner flame , it appears to start "good" but then feathers away from the burner after about 7 or 8 seconds and then stops after 12 seconds . I can hear the gas solenoids operating correctly at start and stop . I am concerned that an underlying fault which is causing this start/stop ,damaged the PCB in the first place and dont want to damage another . I have checked the flu and it is corroded at the outer end , could this cause the start/stop symptom and if so how do i replace/ repair it.
