Guest
Thanked: 0 times
Posted: Mon Nov 25, 2002 11:10 am Post Subject: fence repair |
how can i repair a post and rail fence which has concrete posts and the wooden rail is rotten. |
DAZB
Joined: 10 Sep 2002 Posts: 765 Location: United Kingdom Thanked: 0 times
Posted: Mon Nov 25, 2002 5:38 pm Post Subject: Re: fence repair |
How do the wooden rails attach to the concrete posts? |
Guest
Posted: Thu Nov 28, 2002 2:02 pm Post Subject: Re: fence repair |
the wooden rails slot into perpendicular grooves in the concrete post. |
Guest
DAZB
Posted: Wed Dec 04, 2002 12:37 am Post Subject: Re: fence repair |
Detach the wooden rail from the fence and replace with new timber like for like.If you buy untreated timber then give it a coat of preservative first, especially any cut ends. |
Guest
Posted: Wed Dec 04, 2002 8:53 am Post Subject: Re: fence repair |
How can I get both ends of the rail into the slots in the concrete posts if the posts cannot move?Do I have to cut the rail in half and rejoin it afterwards somehow. |
DAZB
Posted: Fri Dec 06, 2002 12:17 am Post Subject: Re: fence repair |
You could try soaking the timber overnight in water which will make it a little more pliable and then you may be able to bend it just enough in the middle in order to get both ends into the slots.It will be a two man job and will depend on the length of your timber as to how much bend you will get but be careful it doesn't snap.Let me know how you get on . |
Guest
Posted: Mon Dec 30, 2002 3:21 pm Post Subject: Re: fence repair |
How about sliding the panels in from the top ( as they should be !!) |
DAZB
Posted: Sat Jan 04, 2003 5:40 am Post Subject: Re: fence repair |
It's not that type of fence although I thought that at first. |
