Soil Stack Access Point - Does it need expansion
8 Oct 2007
Bristol
I'm putting up a new soil stack. The layout is as follows:
Underground Socket
Plain pipe
Access point (double socketed)
Pipe (socket at top)
92.5 Tee for toilet (socket at top)
Offset bends - pipe - vent
Question is do I need to allow for expansion between the Underground socket and the access point? As in, do I have to withdraw the pipe by 10mm for each of these sockets? If so, do I then need a bracket on the access point?
it would be prudent to allow for expansion.
You haven't given any pipe lengths, but FYI...
[url=http://www.brettmartin.com/building/soilwaste/technical_guide/design/function.aspx]Brett Martin[/url] said:
THERMAL EXPANSION
PVCu has a coefficient of expansion of approximately 0.06mm/m/ºC. Consequently a 2m length of soil or waste pipe
will expand by 2.4mm for a 20ºC rise in temperature. This expansion is taken into consideration in the design of
systems and components, and must be accommodated when installing. A similar allowance should be made when
installing polypropylene and MuPVC systems.
Thanks for that.
The bit of pipe between the access point and underground socket is 6". The 2.4m pipe in the top of the access point has 10mm expansion space at both top & bottom. This is why I was thinking the 6" pipe wouldn't need it as the above gap can take up any expansion. My concern was really that there it's tricky to put a socket clip on the access point and without one it may slip downwards, loosing the gap provided, but making the gap for the above pipe too large.
For a 6" length of soil pipe you need to allow a 0.2mm expansion gap.
Read between the lines..... ;)
