Smeg Induction Hob - 4 wires!
5 Sep 2003
Hi to anyone who can help!
I have a 7.4 KW Smeg Induction Hob with 4 wires:
1 x Earth
1 x Brown Live
1 x Black Neutral
1 Blue and 1 Grey clamped together - what is this for and where do I wire it? Nothing in the manual - just says refer to qualifed sparky etc
I'm assuming this appliance should simply be wired to my 40 amp / 6mm Cooker circuit (?), but the matching 3kw Smeg Oven should be wired to a 13amp plug and then plugged into a Ring mains socket?
Or better to take a 6mm cable from the 45amp Cooker switched socket to a 13amp FCU for the oven?
Any help deeply appreciated!
Keep the hob and oven separate. You'll need all of the 40A circuit to drive the hob at full belt. Plug the oven in too and you'll have nothing to cook on......
You are coorect. The oven can go to a regular 13A socket.
No idea about the connections without seeing it. Some of these are capable of connection to three phase but come ready to go for single phase. If the instructions say "refer to qualifed sparky" I suggest you do that.
Alternatively you could post the query - with the model number(!) - on the appliances section.
Hi
Thanks for the quick Reply
The model is Smeg SE640ID, will post as you say...I can also take a picture of the wiring diagram if this will help anyone?
Thanks again
Alan
