DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Honeywell Thermostat T6360/4360.
Author Message
seamusr
from United Kingdom
PostPosted: Tue Feb 12, 2008 12:30 am Reply with quote
Can anyone help?
I have just bought a Honeywell thermostat model no - T6360/4360 to replace my old Honeywell thermostat.
The wiring to the existing thermostat is three wires - live, neutral and earth. However, the new thermostat comes with wiring instructions for four wires. Live, 2 x neutral and earth.
I have tried wiring the three wires to the same numbers as existed on the original thermostat. Unfortunately, the boiler 5 amp switch fuse blew.
Has anyone any idea what terminals should be connected to what wire.
A wiring diagram is linked : http://www.honeywell.com.pl/pdf/automatyka_domow/termostaty/T6360.pdf
Trouble is - which one do I use.
Many Thanks
Seamusr
Back to top
 Alert Moderators
mikely
from United Kingdom
Thanked: 72 times
PostPosted: Tue Feb 12, 2008 1:25 pm Reply with quote
The wiring to your existing thermostat will not be live, neutral and earth, it will be live, switched live and earth. You don't say which version of the thermostat you have, but assuming it is a 6360B, which is the most appropriate for central heating, this includes an anticipator heater. For this to work, you have to have a neutral connection to the unit, hence the requirement for the additonal connection. If you don't connect the neutral, the unit will still work but its control response will not be so good - as explained in the Honeywell note under 'Mechanical Thermostat Control'. The neutral is also required to make the indicator lamp light.
Your four connections should be terminal 1 - live, terminal 2 - neutral, terminal 3 - switched live, earth.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 1094 times
PostPosted: Tue Feb 12, 2008 5:25 pm Reply with quote
Which means that you will need to run a new (three core and earth) cable to your thermostat. icon_sad.gif
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Help fitting a Honeywell Thermostat T6360.( C/heating) 6 5420 Sat Nov 05, 2005 6:33 pm
Replacing a SATCHWELL thermostat with a Honeywell T6360 3 6200 Wed Nov 23, 2005 3:22 pm
honeywell T6360 room stat 5 1520 Tue Dec 09, 2008 2:23 pm
Honeywell CMT921 Thermostat 2 440 Mon Dec 07, 2009 12:48 pm
Honeywell Thermostat cylinder 2 240 Fri Aug 14, 2009 1:42 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
